Vortech boost question
Old Feb 16, 2006 | 04:57 PM
MechEE's Avatar
Originally Posted by Q45tech
Even with intercooler what is the plenum inside air temperature at 9 psi boost?
Pump Octane ratings are measured in a special low tech test engine at cool temperatures [inside lab 72F]..........they mean nothing in a modern supercharged engine.
Simple to test, try a tank of 100+ octane unleaded racing fuel........knock goes away = fuel and compressed air temperature problem.
Well duh I'm sure it's a fuel in combination with high compressed air temperature issue. You can almost always transform the problem that way. He can try and patch it with some timing changes, increase fuel octane, cool it down some more (richen it up a bit?), or inject some water.
Old Feb 16, 2006 | 05:06 PM
urban's Avatar
Well I think that is what I posted in the first post, I said either cooling IC temps, adding injection system or better octane. I understand that the engine we have is high compression so it is not really made for boosting, not like my TT car which is an 8.5.1 and boosts 21psi with no problem, just an upgraded fuel pump and larger injectors.
I just wanted to really know if our engines can handle 9psi with the stock block and if I need to worry just yet, I also wanted to know if 9-10psi was the limitation of what the stock block can handle until I drop the compression to 8.5.1 with the rebuild planned.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
