Low Temp Thermostat
Originally Posted by hyperlitesmu
It's not all that big of a deal....I mean it mainly just turns your fans on at a lower temp......but your fans are already on anyway.....IMO not worth it.
To stay cool in traffic/track, you need a manual fan overide switch.
Originally Posted by Madelinot
Is there any plug&play switch kit available yet for that purpose?
Lower temp stats do not affect the fan on/off settings, and therefore will only keep your car cooler when cold air is available without the fans (outside air at speeds).
Originally Posted by DP03
Well, not really. A lower temp stat will keep your engine running cooler on the open road. It will not keep the engine cooler at the track, when you're in line at idle. A lower temp stat opens and closes at diff temps. The fans are a different issue.
........Touche' DPO3.......touche'
I'm running the Nismo low temp. termostat but after one year it gave out.
Many people had problems with the Nismo.
I'm going to be using the stock one insted.
I'm running no thermostat because in Florida it doesn't get very cold. I wired a fan override switch and it only took about 30 minutes to do. The fans are hooked to a relay. Just find the switched ground output and hook up your switch the throw a ground signal. Relay is located by the battery.
Did you car overheat? Was it worth it while it was working?
Originally Posted by edv2122
Thats scary.
Did you car overheat? Was it worth it while it was working?For the money it wasn't worth it for barely one year.
My car now doesn't heat up at idle, I need to rev it passed 3k to get any kind of heat.
Will be putting back the stock thermostat this spring.
BradMD_96
Oct 6, 2015 09:31 AM
