Stillen SC Drive Ratio?
Old Mar 18, 2006 | 01:55 PM
ballisticus's Avatar
After I get 70000 miles on the sedan and the drivetrain warrantee is over, I am going to get the Stillen FI. My question is that I have the UR pulley set installed. I would like to leave it on mainly because I dont want to have to take the time to remove it.
Since it is a 15% underdrive, can I just install the Stage 3 pulley and approach the designed Stage 2 blower RPM? What will be the final ratio with that combination? Thanks in advance to those in the know.
Old Mar 18, 2006 | 02:31 PM
luongdmd's Avatar
if you keep the ur pulley set, you will loose boost.... so you might be on the money....
Old Mar 18, 2006 | 04:00 PM
superchargedg's Avatar
stillen says dont use any kind of underdrive pulleys.
Old Mar 18, 2006 | 04:03 PM
luongdmd's Avatar
you can use the kjr ... same size but lighter...... it helps..... from other who have it...
Old Mar 18, 2006 | 08:16 PM
What is the KJR?
Old Mar 30, 2006 | 05:18 PM
nate4598's Avatar
Just go to stage 4
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Spartan268
Aug 20, 2015 09:14 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
