FI Maintenance?
FI Maintenance?
For all you FI gurus - one question I have (and have heard from many others) is regarding maintenance. I have heard that Turbos require more maint than SC, but I have never heard what exactly this extra maint involves. Can someone clear this up for us? Thanks!
Not sure on the others but my HKS is pretty much Maint. free. It has its own oil tank with a special syn. "traction oil" only has to be changed every 60K miles, but from what I hear it's about 125 for the bottle of oil! As for the others I couldn't say. I know the Vortech and a lot of the other SC use oil from the engine, so it is changed everytime you change the oil. As far as bearings belts, etc I have no idea.
I think with a turbo its recommended to have a turbo timer which lets the turbos cool down. From Stillen, "The basic function of a turbo timer is to allow the vehicle to idle the engine for a timed period, with the ignition key removed. This allows the engine oil and turbo center cartridge to cool down and prevent internal turbo damage.The modes estimate the driving RPM according to the vehicles alternator signal and then recommend a count down time."
Originally Posted by MIAPLAYA
Actually in my opinion superchargers have MORE maintenance as you have to worry about belts, pulleys, shafts, etc. With a turbo you change your motor oil and your maintenance is down.
Originally Posted by marchesano
+1, just make sure you check your oil levels regularly and change your oil. That is pretty much it.
1) I check my oil at 1500 mile increments ... the VQ has a nasty habit of blow-by oil that either ends up burned or in the bottom of a catch can. This issue is exaggerated with FI
2) Check belt tension and belt quality at each oil change (A/C belt + driveline belt + sc cog belt)
3) In cool weather (below 50 F) I usually allow the engine to warm up just to the point of the water temp needle at the bottom line... Being that the blower runs on engine oil I want to make sure the oil is warm enough when I start boosting
That all depends on how hard you drive the car and what type of turbo it is. A watercooled turbo needs ZERO cool down time however even non-watercooled turbos need minimal to no cool down time if not driven hard.
Middle of the night take your completely cooled down turbocharged car out for a TEN minute drive around the neighborhood. I did this driving around getting into very mild boost and barely into 3rd gear. After 5 minutes I drove the car back home and parked it in the garage, closed the garage door, then turned out the garage light. Open the hood in the pitch black to find, amazingly enough, orange glowing turbo('s). This was the case for both cars. The exhaust temps alone are enough to generate some serious heat, then add in an air compressor (the turbocharger) and you increase heat exponentially.
Gladly I had a turbo timer in my VR4. What is going to potentially happen is the oil that flows through the turbo's for lubrication is going to cook. Of course better oil takes higher heat before breakdown but when you consider the heat generated it's not worth it. Allowing the car to idle for 2-minutes running oil through the turbo's (without boost) will give you peace of mind. Also mind you I had 120k miles on my VR4 when I sold it and those stock turbo's pulled just as hard as the day I bought it (used).
Just my couple pennies!
Originally Posted by luongdmd
dont' you need to change the filter for the vortech every 3K miles when you change your normal oil....?
