Man what a B#$#h
Old May 3, 2006 | 10:44 AM
mcy4ever's Avatar
Man what a B#$#h
By God... i was at the track and about to do a light luanch on test tune day when all my power cut out and the car was doggin like mad =/. finished the 1/4 mile in 17 seconds haha. Well anyway i noticed my car isnt loud like it usually is "procharger" i get in the pit open the hood and noticed my drive belt had been naded to bits =/. luckly i had an extra belt and my tools on hand. Learned my lesson after nading a belt in the middle of nowhere and having to limp the G to a friends house to do the replacement in the dark with limited tools thank god our waterpump has a seperate belt! Thats the second belt i ve gone through, anyone using stronger drive belts on there SC system? It was a stock gates belt that i blew. Any suggestions would be great. Thanks
Old May 3, 2006 | 11:49 AM
kzanard's Avatar
I don't have a procharger so I can't help you on stronger belts. On my Vortech I was blowing belts every couple of hundred miles and it was a pulley alignment issue. Finally fixed and have same belt now for 1500 miles and counting. FYI, the Gates belts I used lasted longer than the other types I tried (Goodyear, etc.).
Surprised you are tracking it without having it dyno'd. I know you have ECU reflash but I would still have dyno'd to check A/F throughout the RPM range.
Good luck with the belt issue!
Old May 3, 2006 | 12:52 PM
mcy4ever's Avatar
i have a/f guages etc and they are all very conservative in high 10s so im not too worried im running pretty rich at the moment. I just wanted to take a run at the track and get a slip.
Old May 3, 2006 | 04:13 PM
kzanard's Avatar
Gotcha.
Can't anyone else with a Procharger chime in here?
Jessica Ayoub
Oct 17, 2015 02:01 PM
