put nitrous on my g
Old May 10, 2006 | 12:17 AM
quick16's Avatar
put nitrous on my g
i put it on with 100hp pills in it, can i run it like this without retarding the timing? and how do i adjust it if need be?
Old May 10, 2006 | 12:42 AM
papagz's Avatar
i think you will need a UTEC or something like it
Old May 10, 2006 | 01:03 AM
BracketRacerSteve's Avatar
I'm running 100 shot with a NX wet kit, all I have done is 1 step colder on the spark plugs. I am running a 35 fuel jet instead of a 31 fuel jet to keep it a little richer.
dyno tune shows good af and I'm getting 324whp/372 torque.
Since your running a MT you otta have a window switch.
Old May 10, 2006 | 09:35 AM
quick16's Avatar
so no need for timing adjustments then?and do you have a part number for the plugs?
Old May 11, 2006 | 01:30 AM
No part number right off-hand, but it should be listed in the owners manual, I think mine lists standard, 1 step hotter, and 1 step colder.
I'm running the 280 hp motor, you have the 298hp 'rev up' so your results may vary for A/F, I recommend getting a dyno with A/F measurement at a minimum, if your not using a A/F gauge.
Thebaws11
Nov 30, 2016 12:54 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
NJ6MT
Sep 10, 2015 08:40 AM
jbmw002
Sep 10, 2015 12:54 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
