Electric Supercharger (E-Ram)
Old May 10, 2006 | 04:51 PM
aaronbc's Avatar
https://www.electricsupercharger.com/eramspecs.shtml
sounds like a good "bang for your buck" upgrade. i don't want nitrous and lack the funds for a supercharger. currently i have a stillen air box connected to a z-tube for my intake. they have a picture of the device installed on a 350z:
http://www.electricsupercharger.com/...nstall_top.jpg
anything thoughts/suggestions/things to look out for?
-aaron
Old May 10, 2006 | 05:00 PM
Dark Genesis's Avatar
I've seen alot of those on ebay, I don't think it'll be worth it.
Old May 10, 2006 | 05:03 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
A Florida G35 Club member has one and it has the folks that have track tested it.
Old May 10, 2006 | 05:04 PM
Foo_G's Avatar
i dont think it is that make and model though. His is by a company out of South Fl.
Old May 10, 2006 | 05:08 PM
codeflux's Avatar
what... is... that...
ATL_Red_G35's Avatar
I have 3 of them in my CAI and gained about 90whp with it. Good mod. Best bang for the buck.
NOT. It's a waste of money. Your intake are already strong enough. That thing will just be in the way. Many people have tried it and it's a total waste of money.
Old May 10, 2006 | 05:09 PM
Foo_G's Avatar
sort of an electric turbine for the air intake.
The one I seen in the FGC car was much more elaborate than this one and had an array of batteries to power it.
Old May 10, 2006 | 05:11 PM
codeflux's Avatar
4-6% increase?... not worth it. if this thing developed at least 3-4 PSI of boost, then i'd think about it.
5. How much HP gain can I expect?
Answer: Gains on stock 4 cylinder to heavily modified 8 cylinder engines have yielded 4-6% increases. That's 5-15HP depending on your base flywheel HP. If you are removing a stock air-box, gains for cool air tubes and cone filters are up to 5HP by themselves. The e-Ram with its 5-15 HP adds to ALL OTHER MODIFICATIONS, so with an intake tube will give over 20 HP of total gain for the e-Ram + intake system.
Old May 10, 2006 | 05:21 PM
This thing will never give enough pressure to produce any kind of PSI. Remember that our stock intake suction system are very strong.
This is just like one of of the tornado. Cool concept, but doesn't work.
Old May 10, 2006 | 08:17 PM
Q45tech's Avatar
Remember that the atmospheric supercharger is already 14.7 psi [minus alititude/baro correction].......usually 13.7 psi past the intake valves.
1.0 psi [real] boost could add 6.8% more power but getting 340 CFM at that pressure is difficult with electric driven units.
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
