The FX-Spot For General discussion of the FX35/FX45
killing AWD?
Old Jul 30, 2007 | 04:48 PM
Mr.Igor's Avatar
killing AWD?
i am considering buying FX35 or FX45 but the always AWD really kills me on GAS. is there anyway i can remove AWD option with a FUSE like the G35X's? i am looking at gas consumption.
Old Jul 30, 2007 | 04:52 PM
Jeff92se's Avatar
Red Card Crew
If these use the same awd system you won't gain much as the car is rwd first and awd 2nd. So if you aren't slipping the rears, you won't be in awd mode.
Old Jul 30, 2007 | 04:54 PM
Mr.Igor's Avatar
I am not sure. it says 2004 AWD. it eats enough gas. so i am thinking stopping AWD.
Old Jul 30, 2007 | 04:56 PM
Jeff92se's Avatar
Red Card Crew
Acutally I take that back. Regardless of if this system is FWD or RWD based, disabling the awd system probably won't net you jack.
Exactly on what technical basis do you think this would help?
Old Jul 30, 2007 | 09:03 PM
Garnet Canuck's Avatar
Traveling Administrator
You'll gain next to no fuel economy advantage whatsoever. ATTESA on the G or FX is only engaged when it senses traction loss......so other than slippery driving in snow or rain, it is going to operate in a RWD mode all the time anyways.
Old Jul 30, 2007 | 09:07 PM
bruddahmanmatt's Avatar
Yup. If anything the added weight of the AWD components probably do just as much if not more to kill your fuel economy more than anything else since the ATTESA ET-S system is primarily RWD until slip at the rears is detected.
Old Jul 30, 2007 | 09:13 PM
Alan's Avatar
if you want fuel economy youre looking at the wrong car.
Old Jul 30, 2007 | 11:38 PM
GixxerSteve's Avatar
Why don't you just get the RWD version and stop trying to remove fuses to save 1 mpg?
Old Jul 31, 2007 | 02:10 AM
Mr.Igor's Avatar
In canada NO RWD!!! only AWD SAVE ME!
Old Jul 31, 2007 | 03:58 AM
Is it that hard to go down to the border and get a US model? Are the regulations that much different? I know that tons of people import the US models into Russia and elsewhere.
Old Jul 31, 2007 | 08:44 PM
RBull's Avatar
Rated M
+1 on this.
Mr. Igor most of the poor fuel economy comes from the VQ itself and the huge weight of an SUV and the AWD system itself. As already said the tiny amount of time the front gears/center diff is engaged would make virtually no difference to your fuel economy.
Old Jul 31, 2007 | 11:40 PM
N50's Avatar
N50
Maybe you are looking at the wrong vehicle if fuel costs are a major concern. AWD or RWD, the FX35 is going to peg you somewhere in the 18mpg (maaaaybe) in mixed driving. I drive and hour to and from work everyday on straight, flat roads. I use the cruise control all of the time and I'm only mustering 20.4 mpg. 4,300 pounds + VQ engine = less than average gas mileage. Just a thought.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Danielek
May 1, 2022 01:28 PM
NailBomb
Oct 28, 2015 07:53 AM
