Transmission Problem?
Old Sep 30, 2008 | 09:19 PM
C_Lawd's Avatar
Vehicle: 2006 FX35 AWD, ~33k miles, OEM 20-inch wheels and tires.
Symptom: When backing with the steering wheel turned to the left, the vehicle hesitates to proceed in the reverse direction. I do not notice the symptom when backing straight or with the steering wheel turned to the right.
Has anyone experienced anything similar? Any help and/or advice is greatly appreciated.
Old Sep 30, 2008 | 10:11 PM
bruddahmanmatt's Avatar
Based on what you're describing, this sounds like more of a driveline issue rather than a trans issue. I noticed that your FX is AWD. Perhaps a problem with your front diff?
Old Oct 1, 2008 | 04:02 PM
C_Lawd's Avatar
Hmmm... could be. Thanks for the tip.
Old Dec 3, 2008 | 09:35 PM
Solekeeper's Avatar
My first instinct, was that your a bit paranoid.. But idk, this sounds weird. Never heard of it.
Old Dec 4, 2008 | 05:07 PM
CreativeDesignZ's Avatar
could it be your putting more strain on your PS pump while turning the wheel one way or anyother causing the hesitation issue? Sounds normal tho man sometimes u need to "blip" the gas a little bit...
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
Jnm07
Sep 5, 2015 01:16 AM
