G35 & G37, Coupes & Sedans
Can't chirp 2nd anymore.
Old May 24, 2006 | 10:15 AM
trey.hutcheson's Avatar
Originally Posted by afr0puff
I can't just pull back on the shifter and it will slide into 2nd. It literally gets caught at Neutral, and I have to give a second effort to get it into 2nd.
That's how my tranny has behaved since day-one.
Old May 24, 2006 | 10:20 AM
G35Gnome's Avatar
^^ That happens to me too. I would say 25% of the time. As far as being able to chirp 2nd in same weather as you, I was able to do it fine everytime well 95% when it was 70 out on tires with 12k on them. Never tried chirping 3rd.
Old May 24, 2006 | 10:42 AM
FI'ed G's Avatar
FWIW, after putting my after market 19's I wasn't able to chirp on 3rd anymore when shifting close to redline. Then I tried shifting fast around 5.5k and i was able to chirp it again, I'm not sure but maybe because of the MREV higher power/tq around 5-6K and die down after 6+K. Also after driving like a Grandma for a while you do tend to forget how to drive the car HARD! I think 2nd is very easy to chirp.
Old May 24, 2006 | 11:15 AM
afr0puff's Avatar
Supa Dupa Moderator
LOL! Dude, you're driving an '05. I drove my friends '05 6MT. You don't know factory OEM notchiness till you've driven an '03. But yeah, it's way worse than what I started with.
Old May 24, 2006 | 11:42 AM
G35_TX's Avatar
Yea the shifter might be hard, but it won't cause the issue you are discussing.
Old May 29, 2006 | 04:03 AM
BocaCoupe's Avatar
G's Up, Ho's Down
Afro, any update?
Old May 29, 2006 | 09:10 PM
DaveB's Avatar
Originally Posted by BocaCoupe
Afro, any update?
I bet with the reset it will be worse. Everytime my ECU has been reset the car feels sluggish. It was the same way with my other VQ. I simply don't understand people's idea that a reset is somehow going to clean up the ECU and restore lost power. It's quite laughable.
Old May 29, 2006 | 09:20 PM
Hanz's Avatar
I have the same prob :/
But it's due to the environment, I've felt my car pull during the first 2K....
i'm getting used to it and it feels sluggish.
Old May 30, 2006 | 10:18 AM
JaxGman's Avatar
You sure your tires arent so bald that they just dont make any noise on certain types of pavement? The only thing that would not allow you to chirp a gear is your clutch not engaging all the way.. or slipping. You should be able to chirp 3rd realtively easy.. i know my car BARKS 3rd pretty stoutly, and leaves bout 15-25ft of rubber on the ground shifting to 2nd gear.
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
w4kj4k
Oct 2, 2015 07:57 PM
gatorglaze
Sep 19, 2015 12:06 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
