G35 & G37, Coupes & Sedans
Only 1 quart of oil in 06MT
Old Jun 9, 2006 | 10:57 AM
  #46
binar's Avatar
Originally Posted by nmanti
Is the engine still consuming oil?
Note that when you drain an engine of oil, there is still a fair bit of oil around the engine. "Most" of it goes to the sump/oil-pan, but not all of it. So even if only 1-2qrts came out you could have still had an additional 1+ in the car. The dip stick isn't a perfect way to measure oil, but it gets the job done. The car has a pretty wide margin of acceptable oil levels, so having an inaccurate measure device doesnt matter too much.
You can put too much engine in a car, that excess will get burned off. That is normal, it will leak until it equilibrates itself.
If the car is still consuming oil, I hope Infiniti takes car of you.
OMG I don't think you understand what you have just done!!!!!
Old Jun 9, 2006 | 01:04 PM
  #47
enoreeriver's Avatar
Thanks for the replies….yes the engine is consuming oil (in my opinion and my dealer’ opinion).
However, the general consensus here is that there is no problem because the dealer is obviously wrong, the dipstick can’t be trusted, and the 40 YEAR OLD co-owner of the oil change shop obviously cannot tell the difference between 1 quart of oil coming out and 4 quarts coming out during my first oil change.
Let’s just close the thread and move on....thanks.
Old Jun 9, 2006 | 01:10 PM
  #48
binar's Avatar
ahhhhh are you sure???
Def post up when you get the official oil consumption evaluation from the dealer.
Good luck!!
Old Jun 9, 2006 | 01:16 PM
  #49
G35_TX's Avatar
Then don't ask our opinion next time.
Old Jun 9, 2006 | 05:41 PM
  #50
Well, I know that you needed an outlet for your MasterDebating. Besides, I got useful information from everyone else.
Thanks again.
Old Jul 11, 2007 | 02:17 AM
  #51
Wow, I guess I was right about this whole oil problem all along? Yep, one engine later and still using oil like a fiend.
Old Jul 24, 2007 | 07:25 PM
  #52
MightyMouse's Avatar
My dealer is full of **** .. they replaced the engine and said that the car is no longer burning oil, even though the last time it was in for oil the entire valve train was tapping and rattling like crazy..
*** HOLES..
they also didn't tighten up my drivers side motormount...
Old Jul 24, 2007 | 08:12 PM
  #53
jdmstyleg35's Avatar
So, in 3K miles, I have either burned 4 quarts of oil, or the factory never put enough in and the dealer did a sloppy job with the PDI inspection and did not catch it.
I went to the dealer today and we recorded the mileage and verifed that the level was full. I am going back in 500 miles to see if the level changes. Either way, I am furious about the possibility that the engine was damaged
Same thing with me, but the oil consumtion has gone down dramatically while the miles have grown. I am at 6,500 and only burn about 1/4 quart every 3,000 miles. Not bad i guess, but it seems to be getting better as the miles go up and the engine breaks-in.
Old Jul 24, 2007 | 09:14 PM
  #54
Blue Lion's Avatar
I checked my oil soon after I bought my car and it was fine. Not throwing stones, but why didn't you check the oil yourself sooner? Good luck.
Old Jul 25, 2007 | 09:08 AM
  #55
That sounds like some question an *** hump dealer would ask..
Why? Because I spent $36,000 on a car .. I shouldn't have to
Old Jul 27, 2007 | 01:49 PM
  #56
V35 Skyline GT's Avatar
6MT Coupe
Same with me, worst being new 1qt/1200mi and now with 21K on odo, 1qt/2500mi. Still unacceptable in todays standards, imo.
Not to beat a dead horse...but my dip stick shows F after 5qts put in with filter change. When dip on L mark and I add 1qt, it goes back to F.
When between H and L (you do the math) it can be considered normal. Running 1/2qt down is of no concern. Running at L or below is of concern.
Thats why those marks are there...whatever...lol
Here some threads thats been around awhile on this issue. They're long but good info.
https://g35driver.com/forums/g-spot/110973-everyone-check-your-oil.html
https://g35driver.com/forums/engine-drivetrain-forced-induction/120735-poll-oil-consumption.html
http://www.my350z.com/forum/showthread.php?t=232332
Old Jul 30, 2007 | 02:44 PM
  #57
Woblin_Goblin's Avatar
That's all the reason to actually check. When I bought my car I checked the oil in my car after driving 1km. Even though it was fine I still regret not checking it before I left the dealership.
Unrelated, I find the most accurate way to measure is to check in the morning after having left the car sitting over night. You get a nice level line that is easy to read.
Old Jul 30, 2007 | 03:56 PM
  #58
6MT Coupe
That's how I check mine as well. No brainer, but I'll mention anyways...check on level ground too
I'm an old motor head and have always checked my oil regularly in every vehicled I've owned.
Every vehicle and engine is different and I always like to know whats going on with it, if anything.
It is sad I have to check every 1000mi with this VQ though
Not flaming the original poster, but if you truely only had 1qt in your pan, your VQ would've sounded like a lawn mower well before that level.
Old Aug 2, 2007 | 01:47 PM
  #59
04NismoV35's Avatar
Just wondering, would running low oil cause a permanent rattling noise that only shows up when the car is warmed up?
Old Aug 3, 2007 | 09:00 AM
  #60
Wow, you think so? If you do then I have a bridge to sell you... Because that almost sounds like it's straight from a car dealers mouth.
There is NO REASON to check oil on any car unless it's a turbo or unless you find a puddle under the car.
If the car comes with a full oilpan, then it should have a full oil pan for AT LEAST 3500 miles (really more like 15000 or more miles)..
Anyone who knows how an engine works should already know this. Oil shouldn't be allowed in the combustion chamber by any way but through the intake. .. The ONLY time you should have oil in there is if the crankcase pressure builds up sooooo much that oil gets pushed into the intake and blown out of the exhaust. That's ok because it's DESIGNED to functioin like that. I can assure you that no one should be pushing that much oil through a PCV to drop their engines down to 1quart before an oil change is due.
These cars are actually letting oil in through the heads and through the piston rings. ..
When downshifting you can generate enough force to actually warp the rings on these cars (or so I'm told).. After my car consumed about 35quarts of oil I removed my CAI and put the stock one on. Upon inspection of the CAI I saw that it was BONE DRY.. There was NOTHING in the intake that was causing my consumption problems(not my PCV)..
These engines, as I've said MANY TIMES now.. "ARE CRAP"
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
