Nismo S-Tune S2 Concept Engine Set
Nismo S-Tune S1/S2 Concept Engine Set
http://www.bulletproofautomotive.com...il.php?ID=4140
Says it for 350z, but would this spec set fit our g's? Hmm. It looks like the s2 is only for the z, but the s1 for n/a vq35's is for both the z and g--Anybody know of anybody w/ the s1/s2 set on?
Since it's S-tune, does that mean that installing it would not void warranty? Anybody know of any importers that can order individual items from the set? But 10k
I've been trying to find an importer that can get any of the individual parts from the s1 or s2 concept set, but have gotten no luck so far--can anyone recommend anyone or any company for this? thanks!
actually nm....i was looking up japanparts and it might run about 6k. still warranty sounds good.
Originally Posted by daniel3ooo
does it add much hp?
1205G-071-001
VQ35DE engine 14-21 days JP ¥34,300.00 US $306.98
REINFORCED HEAD GASKET
For Race use. A Metal gasket with molybdenum coating for maximum reliability with increased engine compression. Spec: phi96.5 t=0.7mm.
1205G-071-003
VQ35DE engine 40-100 days JP ¥251,500.00 US $2,250.86
HIGH LIFT CAM SHAFT SPEC-2
For Race use. 1.INT Cam: Increasing the actuating Angle (238Deg->284Deg), Cam Lift raised (9.5mm -> 11.0mm), static advance: (125deg->135deg) 2.EXH cam: Increasing the actuating Angle (240deg->268deg), Cam Lift raised (9.5mm -> 10.5mm), static advance (112deg->115deg) 3.VTC operation (Stock being 35deg(s) from the crank angle): changed to: a Overlap VTC OFF 18deg and VTC ON 53deg. Made to order (Take 1-3months).
1205G-072-001
VQ35DE engine 14-21 days JP ¥29,600.00 US $264.91
VALVE SPRINGS FOR HIGH LIFT CAMS
For Race use. Reinforced Springs for high lift cams which can be used for the VQ,VK system engines. The quality of the material and shape of the highest level were adopted by the single spring which can share production head valves and retainers. - A high lift (valve : 9.2->11.0mm) and alignment Load (at the time attachment: 196 ->245 at the time opening valve: 433 ->568N). - Material changed from: SWOSC-VT -> SWOC-VX. - Line (phi3.30round section -> 3.00x3.75 oval section). - There is a 1mm adhesion margin even at 11mm of cam lift. The price is for a set of 24.
1205G-072-003
VQ35DE engine 40-100 days JP ¥260,600.00 US $2,332.30
CYLINDER HEAD SPEC-2
High compression ratio cylinder head for race use. INT valve sheet inner diameter f32.The combustion chamber is cast and processed with the same basic application as the VQ30. Capacity was decreased from 56cc (Stock) to 46cc (NISMO). Compression ratio therefore is raised from 10.3:1 to 12:01. The intake and exhaust ports are optimized for their highest potential. The Spec -2 further increases the inlet valve diameter to 32mm, resulting performance greatly exceeds the Stock VQ35 Stock engine. Made to order (Take 1-3months).
1205G-073-001
VQ35DE engine 14-21 days JP ¥80,000.00 US $715.98
VQ35 TITANIUM VALVE SYSTEM
Only for NISMO CYLINDER HEAD SPEC-1 and SPEC-2. For a High revving NA engine, it's essential to have a lightweight valve/spring assembly to ensure reliable horsepower increase and acceleration. The answer; Titanium valve springs and valves VK45 Weight comparison: INT (Stock 51.4g ->NISMO 31.0g) and EXH (Stock 46.8 g ->NISMO 28.7g).
1205G-061-023
V35 CPV35/ VQ35DE 10-15 days JP ¥6,600.00 US $59.07
IRIDIUM SPARK PLUG SET/ NGK
Plug shape: Long reach type. #6 or #7. Central electrode: Iridium, 0.6. The price is for a set of 2. With register.
1205G-074-002
REINFORCED CONROD BOLT SET
For Race use. NISMO High Rev Bolt sets for Stock Con-Rods used in Race applications Using SNCN, fatigue strength was raised 40% over Stock bolts. * 7,200rpm ability; Torque setting differs to Stock. The price is for a set of 12.
1205G-071-003
1205G-072-001
1205G-072-003
1205G-073-001
1205G-061-023
1205G-074-002
Good find Ivory! I was actually only immediately interested in the ecu, carbon engine cover and intake set, lol, I guess those items can only be had by ordering the whole set? nismo.jp list the S2 concept to only fit the 350z, while the S1 according to them is for both 350z and g35 coupes, but I thought the same engine is used
Originally Posted by IvoryGT
the heads make the compression go up to 12:1 and with the valve and springs you are looking at much higher redline, dare I say 8K at least? since our car makes more hp around the top end, I could say it could make some significant hp but not as much as a turbo would give you. Also it turns the car into a 3.0 Litre displacement.
it lowers the displacement but increases performance without a turbo???
It lowers the displacement and the factory pistons therefore raises the compression. less space higher compression.
