G35 & G37, Coupes & Sedans
Valeo blades, not so good on passanger side?
Old Jul 5, 2006 | 07:14 PM
G35 Mass's Avatar
Just installed my $40 pair of Valeo blades, 22" and 18".
I am getting a 4" uncleared swipe, about 2" in from the outside of the passanger side sweep. Overnight I left the blade excessively bent, trying to form a better curve into it, and it hasnt gotten any better, nor and worse.
Old Jul 5, 2006 | 07:38 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
which model did you get, 417A or 417B? It might be 418A and 418B.
Regardless, you should have gotten the B version since that one comes from Valeo with more of a curve than the A version
Old Jul 5, 2006 | 08:31 PM
G35 Mass's Avatar
That would be type B-Bravo!
When I stoped the blades mid-sweep by killing the ignition, I found that the part that WAS sweeping water well had the blade perpendicular to the glass, like it was standing on edge, the same is so for the entire driver's side.... Should it be more rubbing on it's side, as depicted on the back of the box and in the folowing picture....
If its supposed to be that way, possibly the springs on the wiper's arm need some attention?
Old Jul 5, 2006 | 10:36 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I believe you're confusing Bosche ICON with Valeo.
I have both on trial now...
The ICON comes with a "B" curve for the passenger side;
the Valeo doen't.
However the Valeo can be shaped to curve a little more on the passenger side.
Out of the box my Valeo was missing about 2" near the bottom on the passenger side.
I carefully bent a little more curve into the blade near the end & it's perfect now
Old Jul 5, 2006 | 11:04 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
you're right. brain fart.
i have and was talking about the Bosch Icons.
my bad
Old Jul 5, 2006 | 11:09 PM
G35 Mass's Avatar
There was a B at the end of the valeo part number so i just agreed
Old Jul 5, 2006 | 11:14 PM
IvoryGT's Avatar
Never had a problem with them. People were calling me crazy for buying them...
Old Jul 6, 2006 | 12:28 AM
mordak's Avatar
Or you can just put rain-ex on your windows...then you dont even need wiper blades
Old Jul 6, 2006 | 02:18 AM
G35 Mass's Avatar
RainX is junk, you can never get it completely off your window.
Old Jul 6, 2006 | 03:32 AM
G35 Mass's Avatar
MrElussive, can you stop the blad mid-swipe, both on an up-path and down, and tell me which part of the blade is against the window? Has it "flaped" over and the side is on the glass, or is ist standing on it's edge?
Old Jul 6, 2006 | 09:51 PM
G35 Mass's Avatar
From Tire Rack. Any longer driver side it will be off the window on the top left....
Also, valeo doesnt do Odd sizes, even only... Ill check when I get to work what my book says this is for an 03.0 sedan
Old Oct 31, 2006 | 05:11 PM
BurnsWRC's Avatar
Have any of you used type A on both sides?
Although i ordered my icons as type A and B, they sent me two type A's. They are the right size just both A. Is it a problem? is the difference between A and B huge?
Thanks for the help.
