G35 & G37, Coupes & Sedans
Maxed out sedan vs coupe
Old Jul 18, 2006 | 01:56 AM
evolver's Avatar
If we put aside the obvious difference in the body style, what are the other differences between a maxed out sedan and a coupe? Here is what I could figure out:
1. Sedan does not have bi-xenon headlight (both, lowbeam and highbeam, HIDs)
2. Sedan gets less supportive front seats
3. Sedan may come with a full-size spare
4. Both trims come in slightly different color sets
Did I miss anything?
Old Jul 18, 2006 | 02:31 AM
(>")> G35's Avatar
Bi-Xenons are only on the 06 coupe.
I don't know about the cars when fully loaded, but in base form the sedan weighs less than the coupe, except for the G35X.
Coupe:
AT- 3,505 lb
6MT- 3,524 lb
Sedan:
AT- 3,468 lb
6MT- 3,512 lb
AWD- 3,650 lb
The sedan also has a hair bit better weight distribution:
Coupe: 54/46 percent (front/rear)
Sedan: 53/47 percent (front/rear)
CD is also a hair better on the sedan:
Coupe: 0.29 (0.28 with Aero Package)
Sedan: 0.27 (0.26 with Aero Package)
All specs are from the infiniti website for the 06 models.
Old Jul 18, 2006 | 02:36 AM
ttrank's Avatar
Grocery getter
You can get a full-size spare with the sedan.
The sedans were never offered with Brembo's
Old Jul 18, 2006 | 02:42 AM
dofu's Avatar
20 Year Member
Less aftermarket support for the sedans...
Old Jul 18, 2006 | 10:56 AM
EZZ's Avatar
EZZ
The coupe comes with 19s while the sedan 18s or at least it was in the past model. Different spring rates too for both cars and the coupe tires are staggered.
Old Jul 18, 2006 | 11:07 AM
GT-Ron's Avatar
The weight difference isn't such a shock (afterall, we're talking less than a potential maximum of 60lbs lighter for the given sedan over the given coupe), but the sedan having a better CD than the coupe is.
Old Jul 18, 2006 | 11:11 AM
Scootch's Avatar
i had a sedna just got the coupe 2 weeks ago...and the susp in the coupe is much tighter then the sedan and the handling i find is btr with the front seats it just plantes u...also the touq...is btr in the coupe..put u right in ur seat
just me 2 cents
Old Jul 18, 2006 | 11:50 AM
da mayor's Avatar
coupe you can fold down the backseats, sedans only have a pass through
sedans have in the premium pkg backseats are reclinable
sedans only come w/ 18s on sport package while coupe has 18" performance pkg wheels and 19" upgrades
Rear active steer available on coupes
6mt sedans and ALL coupes DO NOT get convenience of assisted exit/entry where the steering wheel moves up and seat slides back when you get in/out of the car.
also sedans in automatic premium have the rear center vents for the rear passengers, all coupes and 6mt sedans do not offer that
Old Jul 18, 2006 | 02:37 PM
Woblin_Goblin's Avatar
just me 2 cents
Did the sedan have sport suspension? My 03 sedan is much tighter than the 2006 G35X loaner I had the other day.
Old Jul 18, 2006 | 02:46 PM
amg35's Avatar
Florida G35 Club
Absolutely, less support for the sedan.
Old Jul 18, 2006 | 03:13 PM
EZZ's Avatar
EZZ
Originally Posted by Woblin_Goblin
Did the sedan have sport suspension? My 03 sedan is much tigher than the 2006 G35X loaner I had the other day.
There is a considerable difference between how the two feel. The ride is a little on the harsh side on the coupe and the tire stagger makes the coupe feel differently. The tires on the coupe are also significantly better so the limits are much higher. This is all stock of course and you can basically make the sedan handle pretty much the same as a coupe (although I bet the center of gravity will still be a little higher on the sedan).
Old Jul 18, 2006 | 03:40 PM
da mayor's Avatar
G35x does not come available w/ sport tuned suspension..... only rwd sedans can
Old Jul 19, 2006 | 02:19 AM
MrCrazy's Avatar
I'm not suprised that the sedan has a marginally better COD than the coupe. The sedan started out as a concept car designed from the ground up. The coupe basically was designed from the 350Z which was designed from the sedan platform.
Old Jul 19, 2006 | 04:43 AM
Klubbheads's Avatar
I agree with everyones input on this thread.
Old Jul 19, 2006 | 08:47 AM
da mayor's Avatar
the sedan is more of a volume car than that coupe so the price will be marginally lower. and don't forget all cars were build on the same platform so it technically the coupe wasn't built right off a 350z design -- there' s a lot more to it
