G35 & G37, Coupes & Sedans
Patched tire
Old Aug 13, 2006 | 07:39 PM
D87's Avatar
D87
Patched tire
Hey guys, does a patched tire need balancing? Got a nail in one, took it to Chevron and the guy patched it and filled it with air. I put it back onto the car and on highways there's some vibration.
All symptoms point to balancing required?
Old Aug 13, 2006 | 07:48 PM
speedracerg35's Avatar
first of all, the chevron guy probably plugged your tire, unless he took the tire of the wheel. there is usually a little nub that will eventually wear down, but most likely it has thrown your wheel off balance because those plugs can weigh a couple ounces. doesn't hurt to spend $15 to get a balancing.
Old Aug 13, 2006 | 08:34 PM
D87's Avatar
D87
You're right, it's a plug. How do they patch it instead of a plug?
Old Aug 13, 2006 | 08:54 PM
grifter91's Avatar
A patch would require the tire to be taken off. Once taken off they put the patch on the inside.
Old Aug 13, 2006 | 09:14 PM
D87's Avatar
D87
Thanks for the info guys!
Old Aug 14, 2006 | 01:56 AM
(>")> G35's Avatar
Which is better? I heard the plug method was better, but all the times I had a flat, the guys would patch it. They mark the tire and rim with some chaulk and they would try to remount it with the marks lined up.
Old Aug 14, 2006 | 02:07 AM
GLuXuRy's Avatar
fixing it from the inside is the better way
Old Aug 14, 2006 | 02:10 AM
abcquackyxyz's Avatar
yeah patching on the inside is more durable than the plug. cause the plug has some chances of popping out
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
