G35 & G37, Coupes & Sedans
What's the difference?
Old Aug 26, 2006 | 12:08 AM
ChiefyMan's Avatar
I'm confused as to what Nissan/Infiniti did to the VQ to add more power and change the redline on the '06 coupe vs. the older sedans. I'm tryin to figure that out and, if it's not to expensive/hard, I might do those changes to my engine along w/ MREV2 and 5/16 iso spacers.
Thanks!
Old Aug 26, 2006 | 02:00 AM
Calvin's Avatar
Overglorified Altima
do you have a 6mt or 5at?
Old Aug 26, 2006 | 02:17 AM
ChiefyMan's Avatar
5AT in my sedan... is that the main difference or what?
Old Aug 26, 2006 | 03:18 AM
Calvin's Avatar
youre talking about revup engines which are available on the 05 and 06 models
but all autos that i know of are nonrevup
if you want to raise your rev limiter then i think youd have to take it to technosquare if im not mistaken
Old Aug 26, 2006 | 03:19 AM
Calvin's Avatar
btw, if you do take it to technosquare i would take it to them after doing all your mods so they can adjust your ecu only once
ive never looked into TS in depth but im sure its not cheap
Old Aug 26, 2006 | 04:04 AM
ChiefyMan's Avatar
Ya, ECU reflash would definately be my last step.
Old Aug 26, 2006 | 04:18 AM
abcquackyxyz's Avatar
yeah ecu reflash are worth it but pretty pricey.
Old Aug 27, 2006 | 08:15 PM
G35TRG's Avatar
I just got my car back from the dealership yesterday after having them replace the entire motor in my 04 coupe MT for warranty porposes. . They wouldn't tell me what year the new motor was exactly, so, is it likely that they put in an 06 motor or a fresh 04 one? They put the stillen clutch/flywheel in at the same time (why not..). But, I had this exact same question, is it in the ECU, throttlebody, valving, compression, or what? If anyone knows the exact reasoning behind the addition of power, please let me know. thanks.
Old Aug 27, 2006 | 11:20 PM
i love siu mais's Avatar
yep!! ^^
Old Aug 27, 2006 | 11:36 PM
Calvin's Avatar
^^are you chinese?
Old Aug 28, 2006 | 12:40 AM
Skaterbasist's Avatar
Retired SuperMod
All AT's are non rev ups.
Old Aug 28, 2006 | 03:03 PM
DaveB's Avatar
In a nutshell, the Rev-Up motor includes variable exhaust cam timing, better rod bolts, revised higher flowing intake manifold, and a higher redline. The engine trades low end torque for higher rpm power. In an automatic, you'd be slower with the 298hp Rev-Up engine hence the reason the motor is only offered with the 6MT.
Old Aug 28, 2006 | 05:08 PM
G35TRG's Avatar
What makes the power difference between an 04 6MT, and an 05 6MT? Not talking about AT. Anyone know?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
