G35 & G37, Coupes & Sedans
20's 5zr 3 piece BENT!
Old Sep 4, 2006 | 12:36 AM
turbonetics-g's Avatar
Im taking in my wheels to get straightened out tomorrow; the front wheels don't look like they are bent, just the back.
After I put the stock ones in the back, there is still vibrations past 70mph
Why? The rears were more prone to being bent because it is wider (staggered)
The balance is even in the front,
Anyone may know why the car still vibrates at the steering wheel?
Old Sep 4, 2006 | 01:03 AM
redlude97's Avatar
May have knocked you alignment outta wack, get an alignment and see if that helps with your vibration issue
Old Sep 5, 2006 | 05:44 PM
thks, INSURANCE is actually covering it the shop can fix the bends but cannot fix the polished lip or curb rash.. but can cover the lip with aluminum allow coating. Would that look wierd with chrome spokes???
Old Sep 6, 2006 | 09:43 AM
Down_Shift's Avatar
vibrations are usually caused from FRONT wheels. Might not be a bend.. probably just misbalanced?
I went 10.5 rear, 8.5 back so I can have more meat + save myself from getting owned up front.
Edit-- when you said balance is even what does that mean? Alignment or weight balance?
Old Sep 6, 2006 | 07:25 PM
weight balance....
anyways, all 4 wheels are at the shop.
all 4 are bent inside.. the fronts outside and inside...
paying 675 to get them straight.. SUCKS
Old Sep 7, 2006 | 09:33 AM
da mayor's Avatar
ouch well good thign about 3 piece rims is you can replace the outer lip if you need to
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
dseet
Oct 11, 2015 12:40 AM
5150DS
Sep 26, 2015 07:47 PM
