G35 & G37, Coupes & Sedans
Interesting oil filter comparisons
Old Sep 9, 2006 | 04:51 PM
SILVRG35's Avatar
From the comparisons, Purolator Pure One seems to be the best over-the-counter filter.
http://www.bescaredracing.com/sti/oil/filters/compare/
Old Sep 9, 2006 | 04:57 PM
gary c's Avatar
So............if that's what you think
I use K&N oil filters and change my Mobil 1 every
2K miles so it doesn't really matter what I use.
Use what ever filter that "YOU" think is best and I'll
do the same!
Old Sep 9, 2006 | 04:59 PM
HokieZ's Avatar
Yeah, but (at least for the STI) the OEM was the "best" of all.
Old Sep 9, 2006 | 05:01 PM
SILVRG35's Avatar
do the same!
Did you even bother looking at the comparisons? The pictures prove what is the best.
Old Sep 9, 2006 | 05:04 PM
SILVRG35's Avatar
You are right, the tester used the OEM as the control for the test.
Old Sep 9, 2006 | 05:20 PM
FAST1's Avatar
LOL If you change your Mobil 1 every 2K miles, you don't even need an oil filter.
Old Sep 9, 2006 | 05:36 PM
gspotter's Avatar
I thought I was **** doing it every 3K
Old Sep 9, 2006 | 06:12 PM
Silverbolt's Avatar
IMO, Mobil 1 oil filter for the Maxima is the best for our cars.
Old Sep 9, 2006 | 08:25 PM
fortified's Avatar
An Acura tech I know said he has seen more leaks at the gasket area with K&Ns, enough that it surprised him. Of course, most of those K&Ns were on NSXs.
That surprised me, I've never used one but have considered it because it appears to be very robust. Could just be a small interface problem with acura/honda cars.
Many folks like the larger and a little cheaper Mobil 1 filters over K&N and Amsoil, but the Puralator Ones certainly seem to be made well for the cost.
Old Sep 9, 2006 | 08:33 PM
HokieZ's Avatar
Mobil1 makes great filters, but the stock one for both the G and the Z are small (as is the OEM IMO). I like the M1-105. It's about 2-3X the filtration area as the stock M1-108.
Old Sep 10, 2006 | 09:55 AM
bigd23's Avatar
Yeah I always used the M1-105 on the VQ on the Maxima but I didn't think it would fit on the G. I've only changed the oil once on it so far but it looked like the 105 would be too wide to fit in so I went with the 110 which is the same width as the 108 but a bit longer.
Old Sep 10, 2006 | 10:09 AM
HokieZ's Avatar
They fit (BARELY!) on my Z so I'm assuming they will fit the G as well though I admit I haven't actually installed one. There is a bracket on the Z that makes it tight, but it does in fact clear.
Old Sep 10, 2006 | 11:22 AM
Nismo G's Avatar
I use the mobil 1 filter with mobil 1 5w-30. I like the filter it seems to do the job. The OEM filter is an excellent filter...cant go wrong with that one.
Old Sep 10, 2006 | 03:32 PM
Derek173's Avatar
2K miles
Why 2k miles...what a waste of Mobile 1, any true synthetic can VERY EASILY go 5000 miles.
Old Sep 11, 2006 | 04:41 AM
SuperGee's Avatar
I've seen other oil filter studies, and they said the Pure One was somewhat restrictive to oil flow.
What kind of a link if that ... all it shows is photos which you can't get any real info from. You need tests that compare filters in the realm of filtering capacity, flow rate, burst pressure, etc, etc.
