G35 & G37, Coupes & Sedans
Paint flaking on painted engine parts?
Old Oct 4, 2006 | 09:21 AM
vt_maverick's Avatar
Question Paint flaking on painted engine parts?
I'm trying to get various pieces of the engine painted (battery covers, engine cover, intake, etc.), and I asked my guy at the body shop this morning if he could do it. He said that if he paints it with traditional body paint, the paint will probably flake off in a couple months due to heat. He said he could try powder coating it, but the plastic might melt during the baking process. That doesn't make a whole lot of sense to me, since those parts have to already be designed to tolerate the heat of the engine. Maybe the baking process goes a lot hotter? I dunno.
At any rate, I know a bunch of people on here have done this and I was hoping for the exact details on how you got it done.
Thanks!
Old Oct 4, 2006 | 10:17 AM
daveblank's Avatar
It can be done but I can't tell you how. What I do know is that it's not easy to do it right. Basically the plastic is always "outgassing" & it makes it difficult for the paint to adhere. That's how it has been explained to me by a few painters in the past.
Old Oct 4, 2006 | 12:27 PM
bump now that west coast guys are online
Old Oct 4, 2006 | 02:01 PM
absolutg's Avatar
workin...
isn't there a high temp paint you can use? stuff that goes on calipers, etc
Old Oct 4, 2006 | 02:31 PM
I think calipers are anodized. But yes, I think there should be a high temp paint out there. My guy would be willing to do it if he knew how to do it right. He said it's just not good for business if he sells me a bad paint job.
madchef's Avatar
How about this:
Sand the plastic surface down for prep
Prime with a crylon fusion spray
Use high temp paint for the final color
Old Oct 4, 2006 | 02:34 PM
mad, sounds good but I think the main problem my guy has is that he doesn't really have experience with using high temp paints so he doesn't know what he would buy. Do you know of a good product/brand to use?
Old Oct 4, 2006 | 02:53 PM
madchef's Avatar
Duplicolor high temperature engine paint is pretty standard
Old Oct 4, 2006 | 02:54 PM
madchef's Avatar
(sometimes called "high heat")
Old Oct 4, 2006 | 03:59 PM
caskyline's Avatar
Former Vendor
Getting paint to stick is all about the prep work.You can spray all you plastics with regular car paint.You can even spray your engine block if you wanted to. I have my battery covers and MAF sensor tube painted for over 1 1/2 years now.No you can not powder coat plastic.It is baked in a oven at over 300 degrees.G352NV has his valve covers painted.There are many others that have painted their engine covers and battery covers as well.
Attached Thumbnails Paint flaking on painted engine parts?-img_0841_1_6_1.jpg
Old Oct 4, 2006 | 04:31 PM
So if I follow madchef's suggestion with regard to sanding, etc. I should be good to go?
Old Oct 4, 2006 | 05:12 PM
caskyline's Avatar
Former Vendor
Yes,but make sure the parts are clean and dry.Use thin even coats.
Old Oct 5, 2006 | 10:31 AM
da mayor's Avatar
2 years and no issues when i had my old engine painted
jsimonk
Dec 22, 2023 03:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
newg37
Jul 26, 2015 09:32 AM
bickfordbft
Jul 20, 2015 07:57 PM
