G35 & G37, Coupes & Sedans
Anybody have any luck programming Keyless Entry??
Old Oct 23, 2006 | 12:26 AM
nalinc23's Avatar
I have a 2004 G35 Sedan and the keyless unit I got is correct but an extra from the dealership...here are the directions I went by:
1. Get in car, close doors, lock using door button
2. Put Key in and out completely 6 times within 10 seconds and hazards flash.
3. Put key in accessory position, click lock on the key fob.
4. Hit Unlock and Lock on the door
5. Take Key out and Hit Unlock
6. Keyless should be programmed
These directions are for a 2004 Frontier, so not sure how exact they are. I get the car to flash the hazards in step 2, but nowhere further....can anybody help me here??
Old Oct 23, 2006 | 06:21 PM
KiDFuZioN's Avatar
After you get the hazard lights to blink you put the key back into the ignition and turn the key to on but don't start the car. After you turn the key to on press a button on the new remote and the hazard light should blink confirming the programming of the key. Step four is only required if you want to program more than 1 remote. To get of our programming take the key out of the igintion and unlock the door with the door locks and open your door.
Old Oct 23, 2006 | 08:12 PM
nalinc23's Avatar
My remote must have a dead battery because i can clear the code (key in and out 6 times in 10 seconds) but hitting LOCK on the remote does nothing once i put the key in accessory after that....LOL and that leads me to ask...
how the heck do you open the key fob to get to the battery? sheer force?
Old Oct 24, 2006 | 12:27 PM
KiDFuZioN's Avatar
Yeah, you just pop it open from the sides or the bottom of the remote. You have to use a little force to open it.
Old Oct 24, 2006 | 06:12 PM
nalinc23's Avatar
Fresh battery and still doesn't react when i put it into accessory and hit LOCK on the key fob....It's the correct LOOKING 4 button key fob remote....any way it simply wont work with the car?
Old Oct 24, 2006 | 07:14 PM
kev301's Avatar
just like he said, the on postion but don't start the car.
Old Oct 24, 2006 | 08:43 PM
KiDFuZioN's Avatar
You need to make sure you turn it to the ON position, just don't start the car.
Old Oct 24, 2006 | 10:43 PM
thorin's Avatar
Also, don't goo too fast. I could not reprogram; slowed down and it went exactly as advertised.
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
