G35 & G37, Coupes & Sedans
Can you use factory Tweeter Locations on aftermarket install?
Old Nov 26, 2006 | 10:25 PM
nalinc23's Avatar
......if I were to order 6.5 components would I be able to mount the tweeter in the factory location?? I have the non-bose system. I did in my Honda Civic Si I had before this but it was the biggest pain in the world.
-nate
Old Nov 26, 2006 | 10:39 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I did it in my sedan with Alpine Type R components. The tweeter for the Type R's is pretty big but it fits, pushed the grille out a little bit but its not noticeable unless you're really looking for it.
-GP-
Old Nov 26, 2006 | 10:59 PM
nalinc23's Avatar
How tough is it to install those components overall? I broke one of the tweeter housings on my Si by accident I hear the G35 door panels are easy to work with thankfully.
Old Nov 26, 2006 | 11:01 PM
they're very easy to work with. Once you get the panel off (Take off the aluminum trim and there's 2 10mm bolts in the there, and the other bolt under the square by the door handle) there's one or two clips holding the tweeter mount in place, pop em out and there ya go. Very simple.
-GP-
Old Nov 29, 2006 | 05:42 PM
obender66's Avatar
I mounted mine right at the top of factory tweeter grilles-they are aimed better and do not have extra obstriction.
I took out factory tweeters.
Old Nov 30, 2006 | 09:50 AM
SixFive's Avatar
Polk tweets fit perfectly in existing casing
Old Nov 30, 2006 | 09:55 AM
G35lips's Avatar
Florida G35 Club Member
I did not do mine in my G35, but in my prior 350z,(it had the same tweeter location as the G35) I was able to swap them out relatively painlessly. o yeah, I installed infiniti kappa perfect 6.5 components.
Lips
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
keithk831
Aug 2, 2015 09:50 PM
