Carpet
Originally Posted by Q451990
Originally Posted by IP G
thanks i tried there but no carpet just the mats.. the reason im changing the carpet is because i have stone and i want black.. i know it will be a pain but im planning to do my sounds and then change the carpet as well.
The links below are a place in CA – not sure if they will pull off car and ship, but I’ve attached link for your reference anyway… I’m sure FL has salvage yards that you can try too - but CA probably has more cars so the chance of finding a salvaged one might be better.
http://www.pickapart.com/
http://www.pickapart.com/pickyourpartus.html
Good luck.
IP G - did you ever get the black carpet installed? I'm curious to see this because my sister just got herself the new Lexus IS with similiar color interior as the G's Stone but with a black carpet...and it looks absolutely great!
post some pics if you did. thanks
thats exactly why i want to install black carpet because my cousin has the same IS350 with the same color combo.
btw.. no i haven't done it yet.. can't seem to find the carpet anywhere.
I would imagine an OEM set would be the way to go, with it being pre-molded to some extent.
I checked the typical OEM parts suppliers and didn't have any luck either. The only additional thing that I might suggest is checking with ACT(?) or another aftermarket supplier to see if they have a molded replacement kit available.
You could just have your carpet dyed.
I asked Infiniti South Atlanta and they have replacement carpet that that they can order. I have the 04 with black interior except the carpet is grey. Real piece mill job infiniti did here. Anyways, they said it was like $500-600 just for the carpet.
Anything to save a buck I guess...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
