G35 & G37, Coupes & Sedans
Invisicord Install Questions
Old Dec 27, 2006 | 01:27 PM
hwa's Avatar
hwa
A question about the Invisicord install on the Homelink mirror. Search showed a lot of threads edging on what I am looking for, but none that I could find hitting it dead on. When installing the invisicord, instructions direct you to place the cords in position as seen in the attached picture. My question is that are we to place the invisicord wires in the slots occupied by the G35 wire specified in the diagram (ex: place invisicord Yellow wire in same slot occupied by G35 Black+Pink wire), or rather in an unoccupied slot adjacent to one of these wires? I don't anything as it relates to electrical wiring, so some help would be greatly appreciated. Thanks all.
Old Dec 27, 2006 | 02:04 PM
willthethrill's Avatar
you place the invisicord wires in the slots occupied by the G35 wire specified in the diagram (ex: place invisicord Yellow wire in same slot occupied by G35 Black+Pink wire). When I did mine it was a bit difficult to push them in at first but they will slide in.
Old Dec 27, 2006 | 02:21 PM
hwa's Avatar
hwa
Appreciate the help. What will keep the wires locked in place inside the slot?
Old Dec 27, 2006 | 02:42 PM
izmir41500's Avatar
G35driver Addict
can you post pics of your install? I'd like to see what is involved. I've heard it's really easy, I just want to see the slot.
Old Dec 27, 2006 | 09:21 PM
GeeMan's Avatar
It is really easy. Three minute job. At the end of the wires is a flat prong that is held in by the tightness of the slot.
Old Dec 27, 2006 | 09:56 PM
kashrahman's Avatar
Exactly as described above -- you push the invisicord wire into the slot with the existing wire. It's held in by the fact that there's now two wires in the same slot. I tied the wire with a twistie (like the ones that come with garbage bags) around the mirror harness so there wouldn't be any tension on the wire.
Old Dec 29, 2006 | 06:17 PM
hwa's Avatar
hwa
Thanks for the help all. Here is a tutorial I just posted of my experience: https://g35driver.com/forums/audio-video-electronics/132203-invisicord-install-tutorial.html
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
