G35 & G37, Coupes & Sedans
help!
Old Dec 28, 2006 | 08:04 PM
666G35's Avatar
Exclamation help!
last night i started my 04 coupe (23k miles) and there was urgent beeping noise and an orange symbol shaped like a horseshoe with an exclamation point inside it lit up on my console. the symbol is right below the 'not wearing seatbelt symbol' to the left of the speedometer. wtf does this mean?
Old Dec 28, 2006 | 08:06 PM
Blackjack's Avatar
Sounds like you are referring to the Low Tire Pressure light. Check your tire pressure. Was it very cold out? If so, it could have just been due to the temp, but definitely check out your tire pressure.
Old Dec 28, 2006 | 10:48 PM
kashrahman's Avatar
yeah, sounds like the TPS (tire pressure sensor). they're pretty sensitive -- lose a few psi and beep, beep, beep. correct your air pressure and it will take a while (? minutes) before the sensor realizes all is well and stops beeping. Kash
Old Dec 28, 2006 | 10:55 PM
jameyb's Avatar
+1, it is just your tps. Put some air in the tires and you should be fine.
Old Dec 29, 2006 | 11:25 AM
gwhiz35's Avatar
Rtfm
Old Dec 29, 2006 | 11:48 AM
Callaway's Avatar
Originally Posted by gwhiz35
Rtfm
YAAFAH
Old Dec 29, 2006 | 11:59 AM
jameyb's Avatar
Originally Posted by Callaway
YAAFAH
I know what "rtfm" is but what is "yaafah?" That is a new one to me.
Old Dec 29, 2006 | 12:01 PM
gary c's Avatar
Ok..........
If your running the correct psi in your tires a temp change shouldn't make
your tps go off.........could be a nail!
Old Dec 29, 2006 | 04:51 PM
04NismoV35's Avatar
Yup, TPM, I went throught the same the first time it went on. It scared that crap outta, seemed like it laster forever.
It could if there's a drastic temp change. I've seen a 5psi drop with extreme temp changes.
Old Dec 29, 2006 | 04:54 PM
04NismoV35's Avatar
Does anyone else's beep anymore? Mine only beeped the 1st time and never since, but my light has come on plenty of times, as a matter of fact it's been on for a month but all my tire check OK. Must have a faulty sensor, still no beep tho
Old Dec 29, 2006 | 05:15 PM
666G35's Avatar
thx for responding guys.. gonna get it checked out today with my oil change
Old Dec 29, 2006 | 05:16 PM
hwa's Avatar
hwa
reminds me of the LASER warning on a lot of radar detectors....it makes sure you know it's going off..
