G35 & G37, Coupes & Sedans
Fuel Grade.
Old Jan 23, 2007 | 04:31 PM
uk350gt's Avatar
Fuel Grade.
Interested in what fuel people are using. Tried a search so I don't think this has been discussed previously. So, is it the cheaper grade or more expensive and what really should be used in our cars and why - does the more expensive give better mileage or performance or just better for our engines or what?
Here in UK, we have the RON grade (95 or 98). I think you guys have a similar (PON?) which is equivalent but numbering system is a little lower - same fuel though.
I am using the cheaper, but should I???
Old Jan 23, 2007 | 04:43 PM
Plat04G's Avatar
doesnt your gascap/fuel door/gas gauge say Premium Unleaded Only? Or whatever you call the highest grade there. Lower octanes can make the car ping and just not run as good as it should. Most high performance, especially FI cars are Premium ONLY not recommended.
Old Jan 23, 2007 | 05:00 PM
Rphillips6487's Avatar
its recommended to use premium as in our manuals
Old Jan 23, 2007 | 05:04 PM
Beebo's Avatar
premium would be better but u dont need to use it it wont cause damage
preimium is better if u drive fast or race at the track and more mileage
Old Jan 23, 2007 | 05:47 PM
izmir41500's Avatar
G35driver Addict
It has been discussed many many times. The short answer is use what is recommended in the manual.
Here's explanation on octane: http://autorepair.about.com/od/engin...m?terms=octane
It all has to do with combustion. the higher the octane the less detonation/ping/knock you will have. i'm too tired to give a detailed engineering explanation, but howthingswork.com should explain it also.
Old Jan 23, 2007 | 05:49 PM
izmir41500's Avatar
G35driver Addict
Old Jan 23, 2007 | 06:23 PM
kennyz424's Avatar
Very nice... saved me the time to do this for him lol. In the Manual it says we should use Premium Unleaded Gas which is what i use.
Old Jan 23, 2007 | 08:03 PM
mrwhtfks's Avatar
Not sure about the UK but over here there is only about a 20cents difference per gallon from the cheapest to the most expensive. I know I read it on here before, I was using mid grade for a while but the argument made on here was, the difference between the good stuff and medium is really no more than 3 a fill up. What is 3 dollars to get the best that is offered really? Especially when it is what Infiniti is telling us to use?
Old Jan 24, 2007 | 01:26 PM
uk350gt's Avatar
Thanks for all the replies and those that managed to find information through searching, when I could not. I'll start using the premium (98 rated in the UK) from now on. There is a sticker on my fuel cap but of course it is in Japanese (as is the manual) - but I should have guessed at checking the US manual which I do have a PDF of.
Old Jan 24, 2007 | 02:47 PM
bassholic's Avatar
Ok i beleive premium gives better gas mileage....But it could just be differences in my foot. Fill up premium and if you are poor when you drop down to a lower grade you will think you are doing a justice to your wallet...Well enough for a sub or something
Old Jan 24, 2007 | 03:00 PM
uk350gt's Avatar
Post
For those UK drivers, I found the following table of use:
RON MON PON
90 83 86.6
92 85 88.5
95 87 91
96 88 92
98 90 94
100 91.5 95.8
105 95 100
110 99 104.5
Our american friends use PON, we use RON.
Old Jan 24, 2007 | 03:25 PM
fortified's Avatar
Repeating myself again, but Sport Z magazine did a dyno comparison with a Murano. First running it on 87 then 91. Mileage was down only 1mpg on 87, but HP at the wheel was down 10%. You believe most everything else in the manual why not the fuel recommendations?
I suppose if you have a lower compression, economy car and the manual said you could run it on 87 just fine, some folks would run 91 because they think it's better if it costs more.... go figure.
Old Jan 24, 2007 | 04:18 PM
OU812G350's Avatar
92-94 octane super unleaded + 1 can of seafoam # sf-16 once a month...
Old Jan 27, 2007 | 08:19 AM
uk350gt's Avatar
I switched over to Shell V-Power. Do you guys get that over there?
A bit of a burning clutchy smell after some launches. Probably needs to get used to the higher octane fuel, what d'you reckon?
Old Apr 25, 2007 | 02:39 AM
netcbc's Avatar
Who cares about dyno or performance is it safe to run on 89 without car problems????
