In-Cabin filter change problem
Hi,
I just changed out my in-cabin micro filter on my 2004 G35 6MT Sedan following the steps in the DIY section of the forum. Now after I got the glove box lowered I disconnected the plugs that were on the back of it to give me more room to work with. The glove box light bulb plug, remote trunk latch lock plug, and the third plug which I believe is for the airbag system. When I disconnected these plugs, the ignition key had been in accessory mode with the radio on. After having disconnected the plugs I thought to myself that I should probably have the car completely off. So I turned the ignition to off. Replaced the micro filter and everything went fine. When I started the car later after finishing up, my air bag light went off and is now constantly blinking. So I opened it all back up and checked all the plugs, they're all plugged in properly. I then disconnected the battery for a few minutes to see if that might clear something out, and that didn't fix the problem. Has anyone else ran into this problem? If so, were you able to solve it and how? Any help would be greatly appreciated.
Thanks,
Patrick
Thanks,
Patrick
