G35 & G37, Coupes & Sedans
Getting an Alignment
Old Feb 11, 2007 | 04:09 AM
darithS's Avatar
I have a 2003 G coupe, dropped it on Tanabe NF210 springs, do I need camber kits to do an alignment? or no?
Old Feb 11, 2007 | 04:22 AM
redlude97's Avatar
If you want to get back into specs, you will need front and rear camber kits, you can get an alignment without the, and the shop will do the best they can to fix it, but you'll still have to live with excessive wear on your tires
Old Feb 11, 2007 | 09:44 AM
V35 Skyline GT's Avatar
6MT Coupe
^^^What he said.
All they can really do is 4 wheel toe adjustment. Camber is non-adjustable on oem.
They'll adjust for you to track straight, but negative camber will wear the insides of your tires over time without adjustable camber kits.
More drop you have = more negative camber you'll have.
Old Feb 11, 2007 | 08:53 PM
fortified's Avatar
Rear camber is adjustable....as springs settle with a new car, camber will change for the worse. Adjusting it yearly should help from getting it too bad.
But if you plan to lower it will require the kits to keep it in alignment.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
