headlight fuse location?
hi,
i serched but i cannot find it.
i am looking for the fuse for the headlight, the driver side headlight gone,
i pop the hood, i only can find the fuse box in front of the battery, where is the other one?
thx
aaron
thx
aaron
Originally Posted by codeflux
next to the dead pedal (to the left from your left foot when you're sitting in the driver's seat). there is a small plastic door that opens to a fuse box.
yes,
i checked there but there is no fuse for headlight?!
wut can i do?
thx
You are correct, there is NO fuse for the headlight. DOT requires a circuit breaker. It should automaticaly reset itself.
Did you only lose one? If so, it is more than likely the bulb or ballast. Two out would be traced to a fuse or breaker.
Fireman07603
Aug 9, 2015 06:00 PM
