G35 & G37, Coupes & Sedans
Help.... Bad Gas made my G...Die
Old Mar 30, 2007 | 03:25 PM
ososlow24's Avatar
Lastnight I was detailing my G...and I saw a Gas tank in the garage . And stupid meeh was thinking like **** it free gas.... As I put dat **** in....the next day my wife drove it , the car started to choke alot and it die...on the streets , So I got there and put some new gas in it, but now the car runs ok (I Guest) ..but Check Engine Light wont go alway???
Old Mar 30, 2007 | 03:33 PM
Pratik's Avatar
Moderator
Wow, always know what you're putting into your car! I'd take it to the dealer (especially since your check engine light is on). Stupid question but is your gas tank cap put on okay? If its not then you can also get the check engine light. Just a thought.
Old Mar 30, 2007 | 03:38 PM
vaughn6mt's Avatar
hopefully it wasn't an oil-fuel mixture for the ol weedwacker
Old Mar 30, 2007 | 03:41 PM
fhumphrey04's Avatar
^^ thats what I was thinking.
Why would you ever mix random tanks of gas in your garage with a car that requires premium fuel?
Old Mar 30, 2007 | 03:52 PM
TRIG's Avatar
Blame it on the wife! HAHAH j/k
Don't worry if you didn't put that much (1-2 gallons) in it should be fine. Let it cycle through ASAP and don't do that ever again! You just put tons of crap in your cyclinders and pistons. Maybe fuel cleaner will help in this situation.
Old Mar 30, 2007 | 03:54 PM
Nismo G's Avatar
HAHAHA, thats the first thing that came to mind!
-sean
Old Mar 30, 2007 | 03:56 PM
jgainnm's Avatar
Uh oh, just waiting for this to be moved to the Bad Gas subforum.
Old Mar 30, 2007 | 04:18 PM
patrickwong's Avatar
The mods need to move this to the Dumb A$$ section.
Old Mar 30, 2007 | 04:20 PM
ndlive's Avatar
lol good one
Old Mar 30, 2007 | 04:24 PM
omasica's Avatar
HAHAHAHAHA
Old Mar 30, 2007 | 04:38 PM
pullover20's Avatar
FGC general member
wow that was a stupid decision
hopefully it wont cost you too much
Old Mar 30, 2007 | 04:43 PM
repyoself's Avatar
*knock on wood*...
Old Mar 30, 2007 | 04:53 PM
htownboy's Avatar
ROFLOL
Old Mar 30, 2007 | 04:56 PM
Jeff92se's Avatar
Red Card Crew
The CEL won't to away instantly. It will probably stay lighted for xx amount of turns of the key, ie.. until the engine doesn't see that code for a time. Then it should go out. But if anyone hooks up the obdII scanner, they might be able to see past tripped codes.
Old Mar 30, 2007 | 06:52 PM
Beebo's Avatar
LOL
