G35 & G37, Coupes & Sedans
Dash Lit Up Help Asap
Old Apr 6, 2007 | 04:28 PM
DRoQ's Avatar
Exclamation Dash Lit Up Help Asap
Hey guys... I'm on a vacation trip and I'm driving as we speak, I have about 400 miles left and a symbol lights up on my dash. I think its TPS but I'm not sure..I filled up air on my tires 50psi each which is what my tires read. I usually run on 40psi and don't have ne problems does this symbol really mean tps? It looks similar to this (!) and with an underline under the ! Point. What can I do to make this go away?
Old Apr 6, 2007 | 04:30 PM
speedgeek's Avatar
(!) is tire. 50 psi is WAY TO HIGH.
drop it to 32 psi
Old Apr 6, 2007 | 04:47 PM
DRoQ's Avatar
Exclamation
drop it to 32 psi
On michelin pilot sport 19 by 8.5 by 35 front and 19 by 9.5 by 35 rear?
Old Apr 6, 2007 | 05:23 PM
Calvin's Avatar
Overglorified Altima
this question was just answered a couple times this week..
https://g35driver.com/forums/g-spot/149338-help-what-meaning-exclamation-mark-light.html
Old Apr 6, 2007 | 06:59 PM
Msedanman's Avatar
O.F. Administrator
Fill your tires to 35psi....50 or even 40 is too high.
The (!) is for low pressure but may also indicate a faulty TPS sensor in which case the warning will not go away.
C.
Old Apr 6, 2007 | 07:58 PM
LjN_728's Avatar
Wowzers...50 psi! Thank goodness it's not summer yet or definitely they'll blow on you. I believe on the oem Bridgestone 19", it reads max 40psi.
Old Apr 6, 2007 | 08:38 PM
6MTzer's Avatar
40 PSI is right for OEM's, let some air out!
Old Apr 8, 2007 | 02:33 AM
rasetsu's Avatar
50 is way too high. The TPMS just malfunctioned on my wife's G35 last week. Still haven't taken it in yet. A malfuntion is indicated if it flashes when you start the car for a minute and then stays on. It's in the manual. I've checked the pressures several times and they are good at 36psi cold all around.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
