G35 & G37, Coupes & Sedans
"350z style" INFINITI engine cover?
Old May 5, 2007 | 04:31 PM
Drtybrd61's Avatar
has anyone taken a 350z engine cover and rebadged it to infiniti? I've only seen this on the CF aftermarket ones, but never an OEM 350z one. I've looked around but couldn't find a picture or a thread stating that it's been done. Do they make one that comes with the Infiniti logo? I'm not looking to cut my OEM one and I'd preferably like to buy one that comes like this from the factory (not likely though)
Old May 5, 2007 | 05:12 PM
OCG35's Avatar
this is a carbon fiber 1/2 cover (I call it 1/2 cover because it doesn’t have Nissan emblem so it's not really a Z cover)... It is shaped exactly like the Z cover without the Nissan emblem embedded... DaveO helped me custom shape it - as you can see it contours the plenum - I have 1/2" spacer so it gives better clearance, plus helps from keeping heat trapped under the front side of cover... I also cut the front lip to allow for better airflow across plenum (again for cooling purposes)... I'm not a fan of CF look anyway so sanding and painting then slapping an Infiniti logo (coupe trunk emblem that I had black chromed) and this is the end product:
Old May 5, 2007 | 05:20 PM
OCG35's Avatar
BTW, I had to get some alternate grommets, inserts, washers, bolts, spacers and things to get the fit right when bolted down... it was a bunch of trial & error but it's a much better fit with what I have than using OEM hardware. If you chose to do something similar, plan on finding alternate hardware... if you are in LA/OC (So Cal) area try King Bolt (I think in West Covina)... they have everything... that’s where I got everything.
Old May 5, 2007 | 05:42 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
looks goood
Old May 6, 2007 | 07:33 PM
Drtybrd61's Avatar
nice engine bay, OCG35.
anyone got a pic of a 350z one with the infiniti logo? or know if it's possible?
Old May 6, 2007 | 08:46 PM
OCG35's Avatar
just do what I did without shaping/cutting. you'll have a 350Z one with an Infiniti logo.
Old Jun 2, 2007 | 11:36 PM
Drtybrd61's Avatar
so here's some updated pix of my engine bay. My goal is to swap out the NISSAN logo for an INFINITI one. anyone know of a good way to do this?
Old Jun 2, 2007 | 11:42 PM
cipriopt's Avatar
Shouldn't it be just like debadging?
Old Jun 3, 2007 | 01:21 AM
ttrank's Avatar
Grocery getter
You could always get a CF one and paint it. I love the look of the CF.
Old Jun 4, 2007 | 03:44 AM
Drtybrd61's Avatar
naw, I'm not really debadging. I want an INFINITI logo instead of the NISSAN one.
Drtybrd61's Avatar
not really a fan of the carbon fiber.
Old Jun 4, 2007 | 02:38 PM
ttrank's Avatar
Grocery getter
Then you can paint it and put the Mt. Fuji back on.
Old Jun 5, 2007 | 12:16 AM
OCG35's Avatar
I told him that twice - many posts up...
Old Jun 5, 2007 | 12:22 AM
Drtybrd61's Avatar
I'm being stubborn...I want it my way or I'm taking my G and going home!
...j/k
Old Jun 5, 2007 | 12:24 AM
savefatkids's Avatar
try removing the emblem.. filling the area with bondo then sanding it and painting over it. that should turn out nice
