this makes NO sense
The coupe being the manly car of the two, it has more strength hence the weight.
Most people think about the doors, don't forget the bulkier suspension, heavier wheels and tires and the additional cup holders.
Originally Posted by Nismo G
They are reinforced with steal beams in the door and rear quarter panels to help with safety issues. This might be why...but to tell you the truth i have no idea.
-Sean
-Sean
The suspension is the same.....
The sedan has more pronounced sagging in turns as well as oversteer, I drove it, the coupe has better grip on the road period, better control. Larger tires/wheels helps however same suspension? I think not.
The new 07 Sedan handles as well as the old coupe, maybe better.
I won't trade for the new coupe but i'll drive it for kicks.
Do a little research before you spout things.
https://g35driver.com/forums/showpos...57&postcount=1
And I believe there are some differences in the sway bars but I'm not certain of that. Also, I believe the reason for the difference is because of the exhaust not because "it's a coupe".
Nickles
Sep 1, 2015 08:11 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
