G35 & G37, Coupes & Sedans
g35 electric or clutch fan for cooling????
Old Jun 15, 2007 | 01:46 PM
infinitialex's Avatar
On my g35 which is 03 I have a clutch fan and one fan for ac condenser.
Is there a reason that all G35s after 03 have two electric fans instead of one ?
Is not clutch fan more eficient at drawing air?
Can I take the clutch fan ot and replace with electric ones?
Old Jun 15, 2007 | 05:45 PM
ballisticus's Avatar
My 03.5 has only 1 electric as well. I took the clutch fan out 1 1/2 years ago just to see what would happen. Guess what? The car runs fine without it and the electric kicks in when it needs to. Never had the slightest overheat or anything else. Engine revs quicker without the belt driven too. Keep in mind, I live in the NW where it rarely gets above 85F so if you're in Phoenix, forget it. I have also added a remote tranny filter/cooler to negate the effect of any increased coolant temp.
Safest bet is to replace the clutch fan with electric and people have done it. Search. Just wanted to let you know its not really needed, but depends on where you live.
Old Jun 15, 2007 | 07:02 PM
I just saw you are in Sioux Falls. Man, you don't need no stinking extra fan. That's cold country.
Old Jun 15, 2007 | 07:10 PM
Jeff92se's Avatar
Red Card Crew
ballisticus. You just removed the fan assy? Can you still use the oem pulley? Or do you need a 03.5+ pulley?
Old Jun 15, 2007 | 08:34 PM
I just removed the fan from the idler pulley. You have to add a washer or two to make up the thickness lost from the fan mounting face, but I just used a normal washer against the pulley followed by a lock washer, then the OEM nut. Works fine, probably good for a few HP I guess.
Old Jun 15, 2007 | 10:09 PM
hmm,,,,but the fan the electric fan that you have, is it not only for ac condenser and not for the engine radiator?
I live in sioux falls,,,,and today was already on the 90s and it will get hotter so i dont know if it will bea good idea,,,although i do like the idea that my engine will rev quicker...
Old Jun 15, 2007 | 10:58 PM
When the electric fan is on, I can feel the hot air coming through the engine radiator pretty strong so it is definitely removing heat from the coolant. 90's in Sioux Falls huh, didnt know it got that hot there. I went though there in the winter a few years back and never would have thought it possible.
Old Jun 16, 2007 | 03:47 PM
weather here is horrible,,,realy cold in the winter and "florida" hot in summer,,
90s would nto be so bad but the humidity here is a killer, you get outside for 5 minutes and feel all sticky and sweaty,,,,i can't believe i live in this **** hole
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
yassy
Aug 3, 2015 12:24 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
laksjd84
Jul 24, 2015 05:12 PM
