G35 & G37, Coupes & Sedans
Can the G do 160mph?
Old Jun 23, 2007 | 10:40 AM
LudwigB's Avatar
This guy was doing 160mph on the autobahn. I am not sure if it was stock.
Old Jun 23, 2007 | 10:44 AM
steve21's Avatar
wtf? whats this line for?
i would have to say, no.
Old Jun 23, 2007 | 11:09 AM
filanj's Avatar
Not Stock.
Old Jun 23, 2007 | 11:55 AM
mal_TX's Avatar
What can it do stock then?
Old Jun 23, 2007 | 12:31 PM
Nismo G's Avatar
Yes it can, you will just have to have an ecu reflash to remove the speed limiter...i think it will do 156 at 5500 rpms...thats another 1200 RPMS it could probably do 165, but im not sure.
-Sean
Old Jun 23, 2007 | 12:53 PM
GreenGoblin's Avatar
The goblin resurrection
do you know anyone in flordia that does ecu reflash Nismo?
Old Jun 23, 2007 | 05:27 PM
Nismo G's Avatar
I dont think anyone does. Technosquare does reflashes, but you have to send you their ECU. I think AAM does reflashes as well. I am not sure of anyone in florida that can reflash your ECU, but jeremy with the performance factory he can install a utech on your car and im pretty sure with that thing that he can remove the speed limiter.
-Sean
Old Jun 23, 2007 | 05:47 PM
Neal376's Avatar
that was a member on 6mt.net. he had an ecu reflash
Old Jun 25, 2007 | 12:28 PM
LjN_728's Avatar
Could've sworn there was somebody on the board that had actual photos of doing 160 in socal. On the 60 fwy I believe.
Old Jun 25, 2007 | 10:03 PM
TonyG35DG's Avatar
Yes, a guy with flashed ECU ran 170mph (on a down hill highway), showed me the pic of his speedometer on his cell phone. Way too crazy IMO
Old Jun 25, 2007 | 10:57 PM
trey's wife's Avatar
My horns hold up my halo
I have seen my car do 160 (by the speedo) on a dyno but the rollers only registered 155mph. I realize that there is a difference between achieving it on a dyno versus actually achieving it on the road though.
Old Jun 27, 2007 | 07:56 PM
FenixL1P's Avatar
^^ When on the actual road, whether it be open road, racing oval, or aircraft runway, you'll have weight, aerodynamic drag, drivetrain drag, and headwind working against you... unless as mentioned you are going downhill with a 30+ mph tail wind.... but anyway, all the car sees when on a dyno is the drivetrain loss and partial weight.... hope that makes sense...
Old Jul 17, 2007 | 03:30 PM
garrettdn's Avatar
I am pretty sure a G35 running decently well will hit 160+ without the speed gov.
I have seen 150 on the GPS and it was literally still pulling. THat was on a cool day. I have also had it struggle past 140 on a hot, muggy day (and I suspect not the greatest gas).
Old Jul 18, 2007 | 09:11 PM
Kenrik's Avatar
I did 145 mph on flat ground here in florida.
Please Don't tell the FHP on me. it was in the middle of the night on a freshly repaved section of I75
Old Jul 18, 2007 | 10:55 PM
w0ady's Avatar
fgc moderator
speedometers have some error at high speeds. bmw's are notorious for this. i would only truly believe a gps speed for topping out.
