High Mileage / Reliability
#31
#34
Reliability
I have owned about 30 cars including Italian, German, other Japanese makes and my 03 G is by far the most reliable car
I have ever owned. Going on 110k with original clutch. No other issues. Had the car for f seven years with no repair expense only regular maintenance which is key if you want to keep the the car long term.
#35
Most reliable cars I've ever owned was Maximas..started with a 98, retired it and gave it to my son who didn't take care of it and still got 300k..my 01 current drive is nearing 300k and no issues other than replacing a rad last summer...I just got my first G coupe last Saturday..2004 with 136k on it...mint...1 owner was a doctor.
Needed nothing for saftey inspection and nothing for emmissions test.
Hoping for a long run on the G!
#38
#39
This thread is so old...i think i posted in 2007
I have about 75k miles and since then i had a window motor go out and a door actuator. I also had a bad wheel bearing. No other issues...motor doesn't burn a drop of oil but i change religiously every 3750k miles with full synthetic.
Still drives like the day i bought her
faiz23 (01-17-2013)
#40
#41
#42
#44
84k on my 06 revup 6mt G coupe. OC is minimal with about .5 qt every oil change which is "normal". No complaints here. I had a maxima with a VQ with 185k miles and it ran great as well and sold it only to upgrade. VQ's are great. I think that my driver side valve cover may need replacing though as some spark plugs had a little bit of oil on them so I'll have to address that soon.
#45
102,000 on my 03 coupe. Engine is perfect. Wheel shimmies slightly at speeds in excess of 80 mph but that's cause I have a slightly bent passenger side front rim. I need new rims anyway :-)
Had the gear box replaced because 5th gear died but that was 5 years ago. Other than that - no major problems (yet),
