G35 & G37, Coupes & Sedans
High Mileage / Reliability
Old Jan 18, 2013 | 02:57 PM
  #46
vashawn's Avatar
O4 IP G COUPE 110,000 in NY, NY daily driver
CHANGED
-1 a/f sensor
-LF bearing
-all lower control arm bushing-->upgrade to whiteline
-both cats-->upgrade to berks
Old Jan 22, 2013 | 02:53 PM
  #47
ss284's Avatar
145.xxx
Exedy clutch at 138k
New Mishimoto Rad at 139k (oem blew)
New Idler pulley and belts at 140k (oem makes squeels)
New shocks Tokico Blues - and GF210 springs front camber kit.
Need a new front left wheel bearing, makes noises but other then that, absolutely no other issues.
Old Jan 22, 2013 | 08:09 PM
  #48
EZZ's Avatar
EZZ
Originally Posted by rsingerG35
Kind of a waste of oil...
You are probably right but better safe than sorry for me Oil is really cheap too.
Old Feb 4, 2013 | 09:27 AM
  #49
_RR_'s Avatar
Garbage clutch hydraulics, but after two clutches and changing out to an aftermarket clutch slave she is running good at 60k
Old Feb 5, 2013 | 11:14 AM
  #50
Mustang5L5's Avatar
117K miles.
Other than 2 front wheel bearings...no major issues to date.
Old Feb 7, 2013 | 01:58 PM
  #51
Bucszilla's Avatar
Only one current issue: My gas guage doesn't read properly, could be the low or high level sensor?
I just reset odometer at every fill-up and refuel at 350 miles usually.
80K miles on 06 G35 A/T Sedan
Old Feb 7, 2013 | 02:00 PM
  #52
JBz007's Avatar
I've had some issues with my G35 but the powertrain has never been one of them. If you got a powertrain warranty I think you would be wasting your money.
Old Feb 7, 2013 | 03:12 PM
  #53
westbank23's Avatar
2004 6mt brought it at 60,000 miles and so far i have replaced clutch,master clyinder,and cam sensor(this is minus the reguler maintence,brakes,tires,fluids.
im at 107,000 miles and its been burning about 1 quart of oil every 3000 miles..but ive been having that issue since i brought it..other than that its pretty solid
Old Feb 7, 2013 | 03:19 PM
  #54
saywat?'s Avatar
^wat oil do u use?
Old Feb 7, 2013 | 03:27 PM
  #55
westbank23's Avatar
Originally Posted by saywat?
^wat oil do u use?
At first I was useing Mobil one 5w 30 and that was burning 1-2 quarts every 3000 miles but the last couple of oil changes where castrol high milage..
Old Feb 7, 2013 | 03:32 PM
  #56
saywat?'s Avatar
^ah another win for mobil1. u should try changing to convential oil and see if it improves the oC. ive read of that solving most of the OC issue. but never actually known a member here to try and post results. u could be the first
Old Feb 7, 2013 | 03:42 PM
  #57
westbank23's Avatar
Honestly this castrol high milage(non synthetic)has cut down on my oil consumption big time compared to Mobil1..I'm glad I switched over cause I don't feel any difference,it's cheaper and less oil consumption
Old Feb 7, 2013 | 03:57 PM
  #58
RickMack's Avatar
im over 207K with perfect 180-185 compression and i beat the **** out of it.. all stock except plugs and oil! (other then bolt ons) so id say they are pretty damn reliable.. if i aint broke it yet its amazing.
Old Feb 7, 2013 | 03:59 PM
  #59
RickMack's Avatar
oh.. and i use cheap *** oil.. but i do run tx7 in place of a quart.. with in a car of my buddies c5 vette in a 1/4 mile race.. about to swap to an aluminum drive shaft hoping to finally get him with almost 208k and 4 doors!
Old Feb 7, 2013 | 04:16 PM
  #60
saywat?'s Avatar
oh so u did change to dino oil. so it does help. thats great to hear becus there are quite a few with OC issues
u should head over to this thread lol and give your experience
https://g35driver.com/forums/g35-sed...ml#post6690393
