G35 & G37, Coupes & Sedans
Help!!!
Old Aug 18, 2007 | 07:52 AM
Tha_b32185's Avatar
Help!!!
Help what does this (!) <-----mean??...... I just got off work this morning and i I pulled off and shifted it normally. I was crusing in 4th and I hear like a chime noise and this (!) appears. WTF does that mean??? Thanks
Old Aug 18, 2007 | 08:18 AM
dave's Avatar
It means you have low tire pressure.
Old Aug 18, 2007 | 11:10 AM
Calvin's Avatar
Overglorified Altima
check your owner's manual...low tire pressure...
Old Aug 19, 2007 | 12:03 PM
TurK's Avatar
lol its going to blow!!
Old Aug 19, 2007 | 03:42 PM
OCG35's Avatar
If you did not get an audible warning there's a good chance it's a faulty sensor... I went through 4 trips to the dealer with the same issue... They finally replaced the bad sensor.
Check the tire pressure, if it's normal tell the dealer to check each sensor... don’t let them d!ck around reprogramming them and all that crap - it will save you lots of time and frustration!
Old Aug 19, 2007 | 03:45 PM
OCG35's Avatar
check you out with Thuy I bet your smile would be even bigger if you two swapped positions
