Can someone tell me what happened to my clear?
Aug 26, 2007 | 09:31 PM
When I first bought it everything was fine but as the weeks went on some sort of residue sort of "grew" on it. It wont come off and it looks like it was melted.
Its just the left one. My right clear is perfectly fine.
PICS
http://picasaweb.google.com/aamirpro...82999290550530
http://picasaweb.google.com/aamirpro...83016470419730
and here is my left side clear
http://picasaweb.google.com/aamirpro...83046535190850
Reply 0
Aug 26, 2007 | 09:39 PM
where did you get them?
no clue what that stuff is if it's on the outside. does it come off?
Reply 0
Aug 26, 2007 | 09:57 PM
I got them from k2motor and no it wont come off. I cant get it off nor can the car wash people that I get it cleaned by weekly
heres the link http://www.k2motor.com/infiniti3.html
I got the blacked out ones, so many w/e they painted the inside with reacted or something with the plastic? I have no idea
Reply 0
Aug 26, 2007 | 10:15 PM
looks like they melted.
Reply 0
Aug 27, 2007 | 02:07 PM
What bulbs are you usuing in those?
Reply 0
Aug 27, 2007 | 03:29 PM
Quote: What bulbs are you usuing in those?
stock ones that were on the car. I just changed the clear and left the bulb.
Reply 0
Aug 28, 2007 | 07:07 PM
Quote: I got them from k2motor and no it wont come off. I cant get it off nor can the car wash people that I get it cleaned by weekly
Try to get a replacement from them.
Reply 0
Aug 29, 2007 | 01:05 PM
does it still light up? looks almost like your bulb shorted and melted the plastic.
Reply 0
Aug 29, 2007 | 03:25 PM
Soo I called the company and they said they cant replace it because its more in 30 days ( ). So I had an extra set of just plain clears from before and put those on..BUT A NEW PROBLEM THEN FOLLOWS
I changed out my clears and while doing that I attempted to try different bulbs that came with the new ones I bought. That bulb didnt work so I figured the bulb was dead and put the stock one back in. Now it wont light up. All I did was I pulled it out of its socket (the bulb) and put it back in by just poping it into the socket. did i miss anything?
Calvin thinks I might have blew the fuse but the other side works and I would assume they would be on the same ...connection thingy. cant think of the word. Any help would be great. Thanks
Thanks,
-Aamir
Reply 0
Aug 29, 2007 | 04:24 PM
Is the stuff on the inside or outside. I think I know exactly what happened.
About a year ago. I went over a hard bump. The side marker popped out by itself. I was driving around with the side marker hanging from the wires. After getting on the highway, I heard this rubbing noise. I stopped and saw my side marker hanging out by the wires with that black stuff on it.
After weeks of trying to figure out what happened, I found that the sidemarker somehow got between the tire and the wheel well when it was hanging by the wire. The rubbing from the tire pretty much melted into the side marker. If you pull out the side marker and put it into the wheel well you'll know what I mean. The black stuff should match up to where the marker would hit the tire.
Quite a mystery that took weeks to figure out.
Did you have somebody drive your car recently. Maybe they noticed that your side marker popped out and just put it back in.
Not sure if this the same case, but it sure looks like it from the pictures.
Reply 0
Aug 29, 2007 | 05:51 PM
That actually could be it since this side marker pops out ATLEAST once every other month. there have been plenty of times a friend of mine calls me while Im driving and says that he can see from his car something hanging off the side of my car.
Quote: Is the stuff on the inside or outside. I think I know exactly what happened.
Reply 0
Aug 29, 2007 | 08:29 PM
and the moral of the story is....
Don't buy ebay sidemarkers
Reply 0
Aug 29, 2007 | 08:56 PM
There not ebay I searched on this forum for that website and found a few topics on people saying good things about it so blame them Only reason I got it from them and not some bigger name website from the forums is because its the only black I could find blacked out clears.
Reply 0
Aug 29, 2007 | 08:58 PM
Thanks,
-Aamir
Anyone know this problem?DOMO
Reply 0
Aug 29, 2007 | 08:59 PM
Quote: There not ebay I searched on this forum for that website and found a few topics on people saying good things about it so blame them Only reason I got it from them and not some bigger name website from the forums is because its the only black I could find blacked out clears.
Just givin you a hard time, they aren't from ebay, but they are the same generic clear corners that are sold on ebay. Do yourself a favor and get the genuine nissan clear corners and call it a day. They don't even cost that much more than those copies
Reply 0
