G35 & G37, Coupes & Sedans
Tire guru's chime in please
Old Oct 6, 2007 | 11:05 AM
txgcoupe's Avatar
WTF is going on with the 17's??? How the hell do you get only the center tread wearing like that?
Both rears look like this. I constantly monitor tire pressure. Keep them between 30 and 32psi. Door sticker says... 30psi.
About 10K miles.
John
Old Oct 6, 2007 | 04:36 PM
Beebo's Avatar
i thought it should be at 35psi
Old Oct 7, 2007 | 04:50 AM
6MTFTW's Avatar
Its possible that the tire is actually designed that way. If you can verify that there's actually less tread in the center of the tire, using a tread depth gauge, then it looks like overinflation.
-Jerome
Old Oct 7, 2007 | 06:25 PM
GR8TG35's Avatar
Check you tire pressure gauge....it may be off. Looks like over inflating.
If the tread is wearing on the inside portion of the tire,....it means the tires are over inflated. That is why the center of the tire is wearing faster...
If you were under inflated, then the edges, inside/outside tread of the tire would wear faster....
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
DRG35R
Sep 16, 2015 05:33 AM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
