G35 & G37, Coupes & Sedans
Mystery Noise: Sounds like a stone hitting under the car
Old Oct 6, 2007 | 01:25 PM
GWord256's Avatar
I've been noticing a noise, which I can only explain as sounding like a stone hitting the underside of my car, for the past few weeks now. I've been driving around like crazy to try and diagnose the problem and just this week I've taking apart the rear half of the interior and trunk to try and solve the problem.
I have not been able to relate the noise to speed, cornering, or bumps of any kind. It happens on smooth newly paved roads and half @$$ maintained roads with patched potholes. It just seems to happen randomly every few seconds, sometimes more sometimes less, again with no pattern.
Since I've taken apart the car I've tried to remedy possible problems (mostly loose wires) with zip ties and electrical tape to no avail. My only conclusion is that it is not coming from inside the cabin.
Has anyone else had an issue like this and is this a warranty thing that I can take it to the dealer because I give up?
Old Oct 6, 2007 | 01:27 PM
Nismo G's Avatar
Is it a loud noise...almost like a "clunk" or is it soft?
-Sean
Old Oct 6, 2007 | 01:31 PM
GWord256's Avatar
It's definitely no hammer banging on metal noise. Probably something you wouldn't even notice unless you drive the car regularly. It could easily be passed off as just another rock being picked up the wheel and hitting the underside of the car.
I hadn't noticed it until it started getting cooler outside, enough to drive around with the windows up. Now since I know it's there I can easily pick it out.
Old Oct 7, 2007 | 05:36 AM
GWord256's Avatar
Early A$s Sunday Morning Bump
Old Oct 7, 2007 | 09:46 AM
Nismo G's Avatar
I was thinking about it on the way home from a friends house this morning...When the windows are down and you have no music do you hear this pebble clanking noise? Like things are being kicked up off the road to the underside of the car?
Old Oct 7, 2007 | 09:56 AM
OhMyG...35's Avatar
Would you say its more of a ping or a click sound?
Old Oct 7, 2007 | 11:32 AM
Nismo G's Avatar
Im going to say its your rear wheel bearing...try to drive next to some walls or streets that are lined with buildings and see if you can hear it comming from one side more than the other.
-Sean
Old Oct 7, 2007 | 06:37 PM
GR8TG35's Avatar
Maybe the rear axle click problem that plaques us all....Is it consistent at start off or randomly happens while driving?
Old Oct 7, 2007 | 07:41 PM
frshgcoupe's Avatar
I was having the same problem, but i wasnt sure what it was. It almost sounds like when they just pave the streets and u have fairly new tires, the rocks being picked up off of the street is a similar sound. It went away on my car though.
Old Oct 7, 2007 | 08:04 PM
Nismo G's Avatar
It doesn't happen while driving. Its only when you start moving...
-Sean
Old Oct 7, 2007 | 09:26 PM
KevinE's Avatar
Can you elaborate on this for me? I'm pretty sure I have this clicking noise, just wasn't sure if it is something that I should be worried about...
For now, I just turn the music up and drive. Out of sight (or sound), out of mind!
Thanks,
-Kevin
Old Oct 8, 2007 | 03:13 PM
GWord256's Avatar
It really sound like it coming from the inside of the trunk, but I ripped apart half the car and determined thats not the case (maybe I should get a midget to sit back there while I drive around ).
Considering I started noticing it when the weather got colder and I started driving around with the windows up I doubt I'll be able to hear it from the outside of the car with the windows down: however I'll give it a try when I get some time and nice enough weather.
I'd have to call it more of a ping sound.
That'd be covered under warranty, right? But if your talking about a CV joint I know what that is like. I've had 2 go on me in other cars, although they were both FWD. I can't get underneath the car to check them out though.
Kind-of, yes. Except just one rock.
I can only describe it as random. Last night driving home I wouldn't hear it for a mile or 2, then I would hear it a few times in just a few hundred yards. In gear, coasting, WOT, half throttle, no throttle, breaking (haven't tried 100% breaking ). I can't seem to pin down any pattern.
Old Oct 8, 2007 | 09:07 PM
V35 Skyline GT's Avatar
6MT Coupe
You still rolling like this in your weight reduction post?
https://g35driver.com/forums/showpos...9&postcount=80
This noise just start? Or have you had it since your weight reduction project?
Yes...I read your whole thread on that...props to you on shaving 200lbs.
Keep in mine that a noise that we all may have will be heard much easier with your ride like that, if you've had that noise since completion of your project.
Old Oct 9, 2007 | 03:36 AM
EvolutionGSR's Avatar
do you have an aftermarket exhaust?
Old Oct 9, 2007 | 07:41 AM
GWord256's Avatar
I won't deny that there is the possibility that the noise is easier to hear because of the project, but I don't think the cause of the noise is the project itself.
The car is otherwise stock.
I'll take the car to the dealer eventually, but I have no convienent time to drop it off for about the next month and a half
