G35 & G37, Coupes & Sedans
unknown problem please help
Old Dec 16, 2007 | 04:27 AM
V35SKYLINE23's Avatar
hey ive been having this problem lately..i would be on 1rst pushing the gas normally then around 3 rpms i would start to push it..then around 5 to 6 rpms it would just slip through and rev to the higher rpms..i dont know what the problem is can someone help me pleasse, or let me know if youve had this problem too..thanks
Old Dec 16, 2007 | 05:06 AM
Adon's Avatar
check under the hood..... you might have a huge Greddy single turbo that kicks in the boost a little late in the RPM range, and you're probably driving with the traction control off. Turbo lag FTL!
jus kiddin man, that sounds like a weird issue, probably transmission related..
hit up your local trusted dealership and take the guy for a test drive and replicate the issue so he could see for himself
Old Dec 16, 2007 | 03:40 PM
bigugly78cj5's Avatar
sounds like a band/clutches might be slipping... assuming u have an automatic? i dunno if infiniti lets u...but smell your tranny fluid on your dip stick, see if its burnt smellin
Old Dec 17, 2007 | 04:06 PM
thanks uyall, but wen i smell the dipstick, n its burnt then wha?
Old Dec 17, 2007 | 11:41 PM
John Henry's Avatar
Try resetting your ECU.
Old Dec 20, 2007 | 02:30 PM
how do you reset ur ecu?
G35xdriver04
Nov 7, 2015 08:31 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
