Tire question - really need help
Hello,
I've been told several different things, and I figured this would be the best place to get a real answer.
I just bought a 2004 Infiniti G35 Coupe and there is one problem that has been happening again and again.
The tire pressure light will come on, and stay on, after 20 miles or so of driving on the freeway. It will stay on until I turn the car off. But, once I restart the car, it will disappear...
What do you think the problem could be???
Thanks for any help guys!!
if the light comes on with a beep... then it's a low pressure warning. if it comes on with no beep... then there is a malfunction of some sorts. sounds like either a sensor is shot.. or u don't have any sensors even mounted. my winter tires did the same thing after a period of driving... because i simply didn't install any tpms sensors in them.
TPMS Sensor malfunction....?
Chances are you have a sensor malfunction. Most wheel/tire shops don't know
anything about them so you may end up going to the closest Nissan or
Infiniti dealership and discussing the issue with them. They'll be able to pinpoint which tire and how to fix the problem....no cheap/easy fix....
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
