Engine sound at idle - any mod to change it?
I'm not sure about the rest of you, but my VQ sounds a bit "agricultural" at idle. Is there any mod to change this to something nicer?
Did a search, turned up nothing.
lol "agricultural"? like a tractor? or a lawn mower? I like the way mine sounds as it is (then again its the first time I've had a V6, been used to turbos most of my life). Your best bet is to probably get an aftermarket exhaust as well as some replacement cats. What car do you have anyway?
Got Oil....?
What kind of oil are you using? You might try switching to 10W/30 weight
in a synthetic oil like Mobil 1 or my favorite Red Line. My engine doesn't
make any funky noises at startup.
There just seems to be a lot of clatter at idle. Maybe it's the cam chain. My engine is the VQ25DD, same block as the VQ35 but 1000 fewer ccs and direct (in cylinder) fuel injection instead of port injection like the 35. The engine rips at anything off idle but idling cold or warm it clatters.
My last car had a RB20DET which purred at idle and ripped on acceleration. I used to love driving with the windows down nest to walls or between buildings
But it had belt driven cams.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
