G35 & G37, Coupes & Sedans
What gas type do you put on your G35
Old Jun 1, 2008 | 02:42 PM
monkey2003's Avatar
So my brother said pumping the cheapest gas on your G35 will damage your engine because apparantly you are only suppose to pump premium gas. Is this true?? if i can pump regular gas i will but i don't want to if it will cost me in the future to repair the engine. thanks for the input
Old Jun 1, 2008 | 02:50 PM
SoloG35-719's Avatar
premium is always better and recommended dude, just waste the extra 14 cents and take care of your G; She's worth it.
Old Jun 1, 2008 | 03:08 PM
kevink's Avatar
Wish it was only 14 cents. Most places now is 24-30 cents more than regular.
Old Jun 1, 2008 | 03:09 PM
princealyy's Avatar
well i take 35 gallons of gas... a week, so thats 9 a week, or for me 468 dollars a year.
Old Jun 1, 2008 | 03:43 PM
Blue Lion's Avatar
The owner's manual for my 07 coupe says premium, so that's what it gets. That's $.20 more per gallon than the cheap stuff where I live.
Old Jun 1, 2008 | 03:46 PM
BlueDevilBAMF's Avatar
Well if you believe that 87 gives you slightly worse gas mileage then 91/3, you might be breaking even at best.
For some reason people using under 91/3 really bothers me - you paid how much for this car? OK, f*cking treat it like it's meant to be treated. If you want to put 87 in a car, buy a civic and call it a day.
Old Jun 1, 2008 | 03:53 PM
04G35NYC's Avatar
only the best 93.
Old Jun 1, 2008 | 03:57 PM
O HELLA OEM's Avatar
93..
johannaccord1's Avatar
^^ I wish we had 93 here in CA. I use 91 all the way
Old Jun 1, 2008 | 04:09 PM
coolguy8157's Avatar
91 all the times..
Old Jun 1, 2008 | 04:49 PM
mIKE's Avatar
91 is recommended, not required. 87 is required.
Z06/STI/EVO/S2K all say 91 Required, 93 recommended.
those loaners you drive are all on 87
Old Jun 1, 2008 | 05:43 PM
madnaz's Avatar
91/93
Old Jun 1, 2008 | 05:51 PM
xkunalx's Avatar
if i got a nickel for everytime a question about gas type was asked on here, i'd have enough money to fill my tank with *premium*
Old Jun 1, 2008 | 05:54 PM
SDGenius's Avatar
i use 91 because of my TS tune, plus i'm runnin' one step colder plugs. On my Wife's G we run mid-grade though... 89, i think.
Old Jun 2, 2008 | 12:57 AM
optimus310's Avatar
you should really use premium all the time.
because of the compression ratio of the VQ anything lower than 91 oct may cause pinging. The ECU will retard the timing of the engine to avoid this but you will sacrifice performance/MPG due to the ECU adjustment.
http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut12.shtm
