G35 & G37, Coupes & Sedans
save gas in neutral goin down hill??
Old Jun 15, 2008 | 05:44 PM
HITMANVQ35's Avatar
So my friend who has a computer hooked up to his ECU says that he's actually sees less gas being injected while in gear rather in neutral when going down hill.
I was thinking the opposite was true because you're in lower rev range (idling) when in neutral.
If what he is saying is true then how does the car know that its going down the hill and not inject fuel. Does it have a load sensor or some sort? Also if it's not injecting fuel then why do we hear the engine/exhaust sound? Is it just air passing through?
Old Jun 15, 2008 | 05:54 PM
mIKE's Avatar
that is true.
The doesn't know it's going downhill. What it does know that is your foot is not on the gas pedal, and it doesn't have to burn gas to sustain an idle because the wheels are turning the engine.
The noise you hear is the air being pumped in and out of the engine by the cylinders, and mechanical friction.
Old Jun 15, 2008 | 05:57 PM
officerdbag's Avatar
No joke.. My cousins live and die by the neutral thing... They always think it saves gas and pop it in neutral as much as they can.
One of them even throws it in neutral and shuts of the car so it can roll to the next red light.
Old Jun 15, 2008 | 06:00 PM
express705's Avatar
shutting off the car is stupid, and i doubt your cousin does it. no power brakes, no steering... not smart.
Old Jun 15, 2008 | 06:03 PM
This guy has turned into popeye because of it.. Trust me, he did it w/ me in the car and I freaked out.
Old Jun 15, 2008 | 06:05 PM
Q8y_drifter's Avatar
the engine would still be running in Neutral, but at a lower RPM (~750rpm i think?) than when it is in D. The difference is that it is disengaged from the drivetrain. And yes it SHOULD save you gas but the difference would be unnoticable unless you go downhill a lot.
Old Jun 15, 2008 | 06:10 PM
Cux350z's Avatar
^wrong? right? which side are you saying is right?
throw a wideband AFR gauge on your car and see how it reacts to a downhill coast.....or even just coasting.
Stay in gear on a mt = AFR pegs out to max the gauge will read. Means nothing but air is flowing through the exhaust.
Pop it into neutral on a mt = AFR goes to about 14.6 or whatever you idle at. that means gas is running through the motor to sustain operation.
Leave it in gear, the wheels turn the motor for you.
Old Jun 15, 2008 | 06:12 PM
mIKE's Avatar
Shutting the car off does save gas, but the starter was never meant to be used that much...
False economy.
Old Jun 15, 2008 | 06:16 PM
Nikos35's Avatar
don't you use more fuel to start the car then you do by just idle for a minute? we call the neutral coasting "Mexican Overdrive" lol
Old Jun 15, 2008 | 06:17 PM
I think that is a myth.. I'm not sure.
Old Jun 15, 2008 | 06:26 PM
Nikos35's Avatar
pretty sure the ecu injects more on start up..... anyone know for sure????
Old Jun 15, 2008 | 06:40 PM
Maybe.. Because when you turn the key onto battery you can hear the ecu injecting fuel ready for the start up.. I'm not sure.
Old Jun 15, 2008 | 06:47 PM
neight's Avatar
start up fuel is a lot more than coasting, i know on my cbr it fills the fuel rail everytime you turn the key on, it's kind of hard to hear on a car though. i do throw it in neutral sometimes but i guess it would be better to just leave it in gear if thats true.
Old Jun 15, 2008 | 07:01 PM
mIKE's Avatar
Not in a fuel injected car. Def true for older cars though.
Old Jun 16, 2008 | 02:54 AM
HITMANVQ35's Avatar
i see...
thanks for clearing that up
one more thing, how does the ecu know when to transition to inject fuel from when you're in gear to when you go into neutral? Is there a sensor that signals the ecu which gears you're in or is there some sort of load sensor?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
