G35 & G37, Coupes & Sedans
HP vs. Lbs/ft flywheel (torque?)
Old Jul 8, 2008 | 03:49 AM
shawnk3's Avatar
So I was looking at the chart below on Stillen's website [regarding how much power each stage of the Stillen SC adds to each of the two 2005 G35C engines] and was wondering why there's such a large gap between the torque and hp of the two engines [with SC installed] when their normal hp [without a SC installed] is quite small.
For example, the engine in the 2005 6MT has 298 hp which is 6.4% higher than the 280 hp the 5AT coupe from the same year has. But with a Stage 3 Stillen SC installed, the 6MT engine produces 12.1% more torque than the engine on the 5AT....almost twice the ratio of their horsepower difference. A couple of questions:
-Why is there a greater difference between the engines' torque than their horsepower? Is the 6MT engine designed better in some other way (i.e. it produces its peak torque at a higher RPM)?
-Is the torque difference (which is a bigger difference than the horsepower difference) more indicative of the car's performance, particularly acceleration (assuming you negate the gearing/transmission) than the hp difference?
Thanks in advance.
280HP VQ35DE Engines
STAGE 1 - 369 hp / 305 lbs/ft Flywheel
STAGE 2 - 382 hp / 313 lbs/ft Flywheel
STAGE 3 - 410 hp / 339 lbs/ft Flywheel
298HP VQ35DE Engines
STAGE 2 - 390 hp / 360 lbs/ft Flywheel
STAGE 3 - 410 hp / 380 lbs/ft Flywheel
Old Jul 8, 2008 | 01:52 PM
G37Rider92649's Avatar
Stillen SC........No!!!!!!!!!!!!!!!!!!!!!...stupid numbers! Stillen stage 3-4 would get you 310-340whp realistically hahaha.
Old Jul 8, 2008 | 03:21 PM
nchima's Avatar
HKS Stage 3 twin turbo?
Old Jul 10, 2008 | 04:41 AM
Greatwars's Avatar
the info u read.... is indeed marketing
magnetism80
Feb 1, 2019 10:00 AM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
