G35 & G37, Coupes & Sedans
Warrenty Details??
Old Jul 9, 2008 | 01:46 AM
BlueDevilBAMF's Avatar
^^^ Sounds like you need coilovers.
And Beebo asked about Z or G because Tein makes both S and H-tech springs for each. However, you can put Z springs on a G, and most people do, because they drop more than their G equivalents, and they have higher spring rates.
Old Jul 9, 2008 | 05:27 AM
mysterymann's Avatar
I can't lower the car or it will be a bulldozer in my driveway.
The stock height is perfect but I still would like to be able to lower it when its out and about at shows and etc.
so would a set of S techs be good but would the difference between the G and Z be the same as the springs.
Old Jul 9, 2008 | 12:15 PM
Project's Avatar
you definately need coilovers if your thinking about raising and lowering your car like that...as fas as warranty goes they have to prove it but why make it easier on them just keep the stock intake and parts in your garage til you have a problem and switch them out
Old Jul 9, 2008 | 02:29 PM
I will be keeping the stock part in the boxes the aftermarket parts come in.
So would you the Tein S techs or what other coilovers are good. I looked the HKS Hipermax but they were a bit expensive.
Old Jul 9, 2008 | 10:33 PM
Beebo's Avatar
Originally Posted by mysterymann
I also need a set that can keep the stock ride height, but later on at tracks and shows it can be lowered and have all the features
sounds like you need Tein Basics coilovers
Old Jul 9, 2008 | 10:42 PM
Ok i messed up about what i was saying about the S-Techs I thought that was one of there coilovers but its a set of springs.
I was looking at a set of these:
http://sgpracing-store.stores.yahoo....ltykit03o.html
http://sgpracing-store.stores.yahoo.net/tebakit35.html
Old Jul 9, 2008 | 10:48 PM
Beebo's Avatar
if you have the cash get the TEIN Flex but id just get the TEIN Basics... cant go wrong with either...
Old Jul 10, 2008 | 12:34 AM
ok thanks
g.spot
May 9, 2016 10:54 PM
Jeff T
Sep 30, 2015 02:00 PM
cmesidewayz
Sep 29, 2015 09:28 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
