G35 & G37, Coupes & Sedans
wheel pattern? need help please
Old Jul 9, 2008 | 11:51 PM
tylerxfire's Avatar
hey guys hows it going, i am new here just about to pick up my g35, recently was hit and totalled out my chrysler crossfire roadster, i have niche venice wheels that i want to use but the pattern is different, crossfire is 5x112, and g35 i believe is 5x114.3 or something like that, what can i do, the wheels are 19x8.5 on front and 20x10 rear. can they work or what do i need to do to make them work, thanks, also point me in the direction of mods please need to start doing my research on these cars.
Old Jul 10, 2008 | 12:46 AM
OCG35's Avatar
yes 5 X 114.3
I wouldn’t do 19 & 20... but I suppose your could depending on tire size - it would just look odd (front sidewall height would be taller than rear in order to have them both the same diameter).
Old Jul 10, 2008 | 12:47 AM
tylerxfire's Avatar
so would they work though or would i need adapters or something to change the pattern, also do the gs have lug nuts or lug bolts.
Old Jul 10, 2008 | 12:48 AM
OCG35's Avatar
as for mods... I suggest you start the research you mentioned because there are many choices... start here:
https://g35driver.com/forums/tech-area-v35-17/
Old Jul 10, 2008 | 12:49 AM
OCG35's Avatar
ditch the wheels... I wouldnt do what your thinking...
Old Jul 10, 2008 | 12:51 AM
BlueDevilBAMF's Avatar
I'd sell your wheels and save the headache of having to change the bolt pattern, which is possible, but probably not the best idea. Also, running different diameter wheels front to rear on the G probably isn't the best idea either.
Good luck and welcome to the G family!
Also, the G uses lug nuts.
BlackGee35
Jul 31, 2015 11:04 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
