G35 & G37, Coupes & Sedans
04 Copue converting 7443 to 7440 bubls
Old Aug 8, 2008 | 11:28 AM
GQWeApOnX's Avatar
I am replacing my front turn signal bulbs to 7443 to 7440 and i have the 04 headlights.
Would it do anything bad to the car?
Old Aug 8, 2008 | 12:43 PM
RST531's Avatar
So you only want the bulb to turn on when blinking right?
Old Aug 8, 2008 | 01:00 PM
GQWeApOnX's Avatar
Correct =)
Old Aug 8, 2008 | 01:02 PM
RST531's Avatar
ok, check this out. its easy to do and you dont have to hack up your wires.
https://g35driver.com/forums/lightin...r-mod-diy.html
Old Aug 8, 2008 | 09:31 PM
Curt G's Avatar
You might have to grind off a rib from the bulb's socket for it to seat completely. Compare the old bulb's socket with the new one and you'll see what I mean. Use a fine grit grinding stone on a Dremel tool to do it.
The link above might be a better option than using a different bulb.
Old Aug 9, 2008 | 10:52 AM
GQWeApOnX's Avatar
thanks =).
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
orillyon
Oct 7, 2015 05:27 PM
JustinMKN1
Sep 18, 2015 03:40 PM
