G35 & G37, Coupes & Sedans
CEL light on help
Old Oct 14, 2008 | 07:48 PM
lookthatsme's Avatar
CEL light on help
this started happening about 2 weeks ago so i went out and bought a scanner the code came out to P1273 (air to fuel ratio). I have the Injen CAI and helix test pipes with the simu. When i had the X02 exhaust on i never got the cel light then i went back to stock and about 2 days later i got the code? could this be that there is more back pressure and the O2 sensors are going crazy or is it because of the CAI which i got back in April?
Old Oct 14, 2008 | 07:51 PM
Also i get this hissing noise when i let of the throttle say im at 7K rpms and it will hiss all the way down to about 1k. I changed every gasket on exhaust besides headers to test pipes. Every gasket was good but since i bought them already i figured i might as well change them. Im not sure if the hissing noise was there when i had the X02 on there because it was so loud you couldn't hear yourself think
Old Oct 15, 2008 | 07:14 PM
Also i did search but no one has this problem. I forgot to mention the test pipes are non resonated which i think thats why i get that hissing noise. Unless someone could help me out and tell what kind of resistors i need and just get rid of the post cat O2 sensors
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
brownie
Nov 25, 2015 12:50 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
flytim3
Sep 5, 2015 01:23 PM
